It is currently Tue Sep 23, 2025 12:13 pm
Reply to topic  [ 18 posts ]
 Pd lower units
Post Pd lower units
What's the difference in the old lower and the new?
1850 & 36pd
Fri Feb 03, 2012 7:37 pm
Post Re: Pd lower units
Old, completely filled with gear oil. Newer, bottom filled with gear oil and top with grease. Newest, top and bottom filled with grease, only the knuckle has gear oil. Ronnie, please correct me if I'm wrong. :lol:
Fri Feb 03, 2012 9:26 pm
When you order a new lower does a prop come on it or did I dream that up?
1850 & 36pd
Fri Feb 03, 2012 10:17 pm
Not unless you order a new prop with it. Think it comes with a new prop bushing though.
Fri Feb 03, 2012 10:21 pm
18x48 Charles Leonard / 36PD
Fri Feb 03, 2012 10:24 pm
We upgraded because KP wanted us to for some reason and made it worth our while to go ahead and bite the bullet. I keep the old one as a spare.
Fri Feb 03, 2012 10:29 pm
The crazy thing is that one time you may have a little water or milky oil and the next time not. Its time to change a seal when water pours out. Not sure what the cost of a new or rebuilt LU is but its not needed just because you have milky oil. Hell, every boat motor I ever had eventually ended up with leaking seals. I just change the oil regularly and roll with it.
Fri Feb 03, 2012 10:44 pm
That one was pushing out the top every few hours. Want to say that was around 250 hours or so. I know dad replaced one of the seals and not the other. I think he replaced the top seal though for some reason, but can't remember. He tried to sell us the upgrade the first time, but he was very convincing the second time. :lol: I think the gears have a little more lash in them this go around too. Could be wrong, but I think that's what Brian said.
Just gonna keep the new seals and good oil in the old one and keep it around since we have it. It still works fine.
Fri Feb 03, 2012 10:47 pm
How often do you change the oil/grease?
1850 & 36pd
Fri Feb 03, 2012 10:54 pm
I just put a shot of grease in every so often. I will go ahead and change the fluid in the LU when changing the oil cause it's easy and cheap. Doesn't really need changing unless it's got water in it. I think Poker said he tears his down and puts fresh grease in the tower and stuff every year. Not a bad idea.
Fri Feb 03, 2012 10:57 pm
Fri Feb 03, 2012 10:59 pm
I'm gonna go to the pd site and try to find a manual to dload. It might all make a lil more sense for me then. Thanks poker and clay
1850 & 36pd
Sat Feb 04, 2012 12:16 am
I grease mine about every 50 hours. I check my gear oil often because I run a lot of vegetation and always get grass wrapped around the prop shaft.
I gave up mud motors
Sat Feb 04, 2012 6:56 am
Sat Feb 04, 2012 12:15 pm
i do like poker says .just change it about once a month.gear oil is cheap and it easy to change
Sat Feb 04, 2012 8:11 pm
Post Re: Re: Pd lower units
1850 & 36pd
Sat Feb 04, 2012 9:36 pm
What gear oil are y'all using? The manual says 80w90 but I know ProDrive puts synthetic Royal Purple in their new units (or at least they used to) and I can't find 80w90 Royal Purple anywhere.
Sun Feb 05, 2012 5:30 am
Guess I might should change mine. Still got the original lower unit oil. lol
I pulled the top plug last month and good lookin oil came out, so its still got plenty, and pulled the bottom for a sec and no water came out.
Sun Feb 05, 2012 10:42 am
