It is currently Tue Sep 23, 2025 7:28 pm
Reply to topic  [ 21 posts ]
 clutch
Post clutch
is it diffcult to change a clutch on a prodrive
Tue Feb 07, 2012 8:22 pm
Post Re: clutch
Not terribly, no.
Tue Feb 07, 2012 8:23 pm
Post Re: clutch
in an out in 30 minutes
Tue Feb 07, 2012 8:24 pm
Post Re: clutch
really it looked to be hard
Tue Feb 07, 2012 8:35 pm
Post Re: clutch
Just have to find a way to suspend the motor. 4 bolts and the top lifts off, 4 screws and the spline adapter comes off, 1 more bolt and the clutch comes off. I never had any issues getting the clutch off, but if yours is stubborn, you may need a lil penetrating oil. It's a pretty simple job.
Tue Feb 07, 2012 8:38 pm
Post Re: clutch
thanks. i got a half ton cable come along and a aframe i will do it tomorrow
Tue Feb 07, 2012 8:51 pm
Post Re: clutch
Took me 30 minutes to figure out how to keep the motor suspended and about 30-45 to change it. Not too bad.
1748 prodrive 36 fpr w/ some bolt ons...
Thu Feb 09, 2012 6:17 pm
Post Re: clutch
When the clutch goes out does it start slipping first or does it go out totally?
Thu Feb 09, 2012 6:37 pm
Post Re: clutch
depends on what fails in side the clutch
Thu Feb 09, 2012 6:40 pm
Post Re: clutch
Yup. My magnet fried in mine and just went poof while towing another boat back to the ramp..... No warning
Thu Feb 09, 2012 8:15 pm
Post Re: clutch
Thu Feb 09, 2012 8:19 pm
Post Re: clutch
thank for the info. changed it today was pretty simple. clutch slipped no problems. was back in the boat by noon looking for hogs
Thu Feb 09, 2012 8:51 pm
Post Re: clutch
Thu Feb 09, 2012 8:53 pm
Post Re: clutch
i meant to say it slide off the shaft with no problems
Thu Feb 09, 2012 9:00 pm
Post Re: clutch
Sat Feb 11, 2012 12:06 am
Post clutch
when I broke this piece mine was slipping. I think 4 out of 6 were broken
Sat Feb 11, 2012 8:03 am
Post Re: clutch
If I am not mistaken that peice is supposed to be machined fitted to the friction plate.
When that machined fit breaks it lets the friction plate rattle on the magnet and eats away at the plastic coating.
This in turn ends up grounding out and burning up the clutch.
Changed mine last week due to that peice breaking off of the plate and rattling.
I am sure it wouldnt have been long until mines burnt out.
Sat Feb 11, 2012 8:29 am
Post Re: clutch
About how many hour u Can get on a clucth
Wed Feb 15, 2012 10:13 pm
Post Re: clutch
that is a very "depends" question
Wed Feb 15, 2012 10:14 pm
Post Re: clutch
I had 175 hours on my first clutch :shock:
Thu Feb 16, 2012 5:55 pm
Post Re: clutch
I think my dads has a Lil over 300 on it. Mine has been on a few different frames, but I think its in the same neighborhood.
Kinda like a transmission "can" fail at 20k and may last several 100k. A clutch "could" fail at 20 hrs but may last a couple thousand... just never know. Keep them somewhat clean with a good power source and they should last a- long time. Dirty as hell with shitty power may not last so long.
Thu Feb 16, 2012 6:06 pm
