23hp SD Build
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=27238
Page 1 of 2
Author:  sftull [ Wed Feb 29, 2012 2:06 pm ]
Post subject:  23hp SD Build
I have been in the process of building a 16hp SD for a few months now. Here are a few of the build pics so far....I machined/fabricated everything except the welding. I hope to fire it up this weekend on the stand.
Author:  Buzz Killington [ Wed Feb 29, 2012 4:37 pm ]
Post subject:  Re: 16hp SD Build
Right on - looks good =)
Author:  chaseh [ Wed Feb 29, 2012 5:49 pm ]
Post subject:  16hp SD Build
Kick ass man! Looks awesome!
Author:  quack addict [ Wed Feb 29, 2012 7:50 pm ]
That's some nice looking work. Keep us posted on how she runs.
Author:  sftull [ Fri Mar 02, 2012 6:11 pm ]
Here is the tiller handle control box. Tach and dead man switch. All the wires and throttle cable run inside the tiller handle.
Author:  sftull [ Mon Apr 23, 2012 9:41 am ]
Here is a short video of it running.
Author:  mnsherick [ Wed Jul 18, 2012 6:24 pm ]
This is awesome. I've been wanting to build one of these, do you have any details/insight into the build?
Curious, how much does it weigh?
I'll start my build next winter after Duck season.
-Matt
Sent from my PG86100 using Tapatalk 2
Author:  vertical_edge_800 [ Fri Jul 20, 2012 7:33 pm ]
What is the gear ratio and prop? Which pulleys and belt did you use?
Author:  brasso [ Sat Jul 21, 2012 12:37 am ]
That little thing is awesome!! You wanna build me one?
How much does it weigh?
Author:  sftull [ Mon Jul 23, 2012 9:20 am ]
So I have been working to add a clutch to my mud motor. I got the clutch from flea bay and then had to machine an adapter so I could mount my pulley to it.
After I got it put together, I got in a hurry and wanted to try it out. Well I forgot to put the front two mounting bolts in the engine. After about 5 mins of ridding, I noticed a loud racket coming from behind the engine and the belt had walked off the lower pulley and got shredded. Luckily I caught it before it was completely done and was able to limp back to the dock. To change the belt, I have to take the belt housing apart, so I took the opportunity to paint the frame. Getting it ready to camo.
I still need to build a cover for the clutch/pulley setup.
I also made a new pivoting handle after my old, fixed handle, slammed into my knee when I hit a log, I put the control box behind the throttle and added my clutch switch (black one...down is neutral, up is go)
Here is a vid of the cluch working. I need to idle the engine down now that I have a clutch.
Author:  markoutdoorz [ Mon Jul 23, 2012 10:05 am ]
very nice work
Author:  Woodiebuster [ Mon Jul 23, 2012 8:19 pm ]
Very clean homebuild!
Do I see power trim?
Where is da switch?
Author:  sftull [ Tue Jul 24, 2012 5:58 am ]
Author:  vertical_edge_800 [ Thu Jul 26, 2012 4:48 am ]
You should be real proud of that build!
Author:  sftull [ Thu Jul 26, 2012 6:03 am ]
Author:  scott0227 [ Wed Aug 01, 2012 4:21 pm ]
That is kick ass!! Any speeds recorded?
Author:  sftull [ Thu Aug 16, 2012 6:55 am ]
Consistently 23mph deep water with me 170, 6gals of gas, two batteries and all safety gear (life jackets, anchor, fire extinguisher, etc)
Author:  sftull [ Thu Aug 16, 2012 6:57 am ]
Author:  pearl river outlaw [ Thu Aug 16, 2012 7:20 am ]
Looks good man!!
Author:  lastchance [ Thu Aug 16, 2012 10:03 am ]
Nice job!!
Author:  sftull [ Mon Aug 20, 2012 6:42 am ]
I painted the engine cowling over the weekend. It was red and now its black. I think it looks alot better now.
I also built a cover for the clutch and pulley. Its alittle big but it works. I painted the frame green and black, starting the camo process.
Author:  mud slinger 69 [ Mon Aug 20, 2012 6:47 am ]
The Tread says 16 hp .Thats a 23hp isnt it.Looks good
Author:  sftull [ Mon Aug 20, 2012 7:09 am ]
Yea, its a 23....The build started as a 16 but I put a 23 on it half way through the build.
Author:  brasso [ Mon Aug 20, 2012 2:47 pm ]
Post subject:  Re: 23hp SD Build
I liked how you had the neutral and kill on the end of the tiller. Why you did away with that? Are you going to add trim to this, ań eventually make another with it?
Author:  sftull [ Mon Aug 20, 2012 4:19 pm ]
Brasso, after driving it for a few hours the control box on the end of the tiller wore a bad blister on my thumb. To remedy it, I moved the box. It has manual trim but I do plan on adding electric trim.
Author:  Quack Attacker89 [ Fri Aug 24, 2012 5:49 pm ]
Nice build bro. I've been reading up on it here and on duckhuntingchat and I just got a few questions for ya. Did you seal the front of the drive tube or do you just clean out the bottom of the gear housing when grease start to build up? And did you use a hardened steel shaft or just regular mild steel. I'm fixing to start machining the bearing housing and lower seal housing.
Author:  Woodiebuster [ Sun Aug 26, 2012 7:44 pm ]
Now you just need a real boat!!
Author:  sftull [ Tue Aug 28, 2012 6:53 am ]
Author:  dguidry [ Tue Aug 28, 2012 8:19 am ]
Author:  sftull [ Tue Aug 28, 2012 9:45 am ]
Author:  sftull [ Mon Oct 15, 2012 8:01 am ]
During the last outing, I broke my idler pulley which in turn kicked the belt off. To put the belt back on or replace the belt it takes an act of God...well almost. I have to completely disassemble the entire belt housing and remove the pulley from the outdrive. Well I got tired of doing that (had to do it twice) so I built a new belt housing. This one is made from an 8x4 rectangle tube and the other one was 6x4. I also went from a 1600mm belt down to a 1440mm belt.
Now all I have to do to change the belt is remove the bolts that hold the plate onto the belt housing. There are 14 in all and you can see in the picture that some of them aren't in. I still have to get the bottom plate welded in.
I also switched over to a mikuni and the BPS exhaust should be on its way today.
When the belt housing is out for welding, I will replace the crank case gasket b/c it is leaking a small amount of oil. I will remove the remaining gov. setup then.
Author:  brasso [ Mon Oct 15, 2012 9:20 am ]
While you have it pulled apart you might as well go get your heads done, and throw a cam in there!
Author:  sftull [ Mon Oct 15, 2012 9:31 am ]
I already have a cam. Al at PVT can put a gov. on a performance cam and thats what I had him do, so I could stick with the stock carb. Now that I am going with the mikuni, I will be removing all of the gov. setup. Heads will be a next year project.
Author:  brasso [ Mon Oct 15, 2012 9:34 am ]
Sweet, those heads will really wake it up
Author:  sftull [ Thu Oct 18, 2012 12:50 pm ]
BPS Crossover just showed up. :D Its used so it needs to be polished. I'll post from before and after polishing pics.
p.s. I'm not worried about it flaring birds. I cover the engine when I hunt.
Author:  sftull [ Sat Oct 20, 2012 5:45 pm ]
Got the BPS crossover installed and it sounds awesome. Below is a short video but it doesn't do it justice.....sounds just like a Harley. I left the silencer in.
http://s274.photobucket.com/albums/jj25 ... 813879.mp4
I also got the new case together and it works so much better than the other case. If I break a belt, I will actually be able to change it on the water. I still need to build a clutch cover.
I also added three seat bases to the floor. I had them mounted to a bench made from 1" emt but after hunting out of the boat twice, it just got in the way. I think this will be ALOT better.
Author:  rodburner21 [ Fri May 24, 2013 11:36 pm ]
where did you buy the clutch?
Author:  FRANKtheTAU [ Sat May 25, 2013 12:13 am ]
According to this thread he bought it off of eBay.
Author:  cupped up [ Sat May 25, 2013 8:58 am ]
Hey sftull, I just noticed MB's revolutionary transom saver for the sport motors sure looks a lot like your old one...I wonder where they got the idea? :roll: lol
Author:  guidry21 [ Fri Jun 14, 2013 10:47 am ]
hey I want one how much :D
Page 1 of 2 All times are UTC - 6 hours
