backwater7
 HELP!!! Home build
Could someone please help, i buit my own SD Looks great work for 5 min then belt started to slip! could one of yall please tell me what type of pulleys and belt or clutch these motors take. I have a 18h kolar rpms are about 3600, would love some help ive put in alot of time and effort into this build any help would be appraciated also were i could get this stuff would be great!
Thu Mar 01, 2012 6:38 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: HELP!!! Home build
what kind of belt
_________________ You have your whole life to be an idiot, take a day off!
Thu Mar 01, 2012 6:49 pm |
backwater7
i put a 50 inch v belt on a 3.5 top pulley and a 4inch on the bottom i have no clue what type of set up these SD motors use, ive built this motor just buy looking at pics of MD and Gator tail.
Thu Mar 01, 2012 7:05 pm |
CCC
 HELP!!! Home build
Timing belt
Thu Mar 01, 2012 7:58 pm |
BlueShamu
Let's see some pix of this home build!
Thu Mar 01, 2012 8:01 pm |
sftull
Joined: Tue Mar 08, 2011 1:33 pm Posts: 601 Location: Rock Hill, SC
Chain and sprockets...alot cheaper than a timing belt setup and it won't slip!!
_________________ 1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Thu Mar 01, 2012 8:02 pm |
CCC
 HELP!!! Home build
Thu Mar 01, 2012 8:11 pm |
barrelburner
v-belts are not the best, slip too much for this application. Like the other guys said chain and sprockets or timing pulleys with 3/4 to 1 inch wide belts. I used martin H pitch timing pulleys for my build, the H is for heavy duty ba beeeeeeh. Think I had about 150 bucks tied up in them+ the tapered bushings to go in them for the right size bore. Don't give up these home builds will whip your butt if you let them.
Thu Mar 01, 2012 8:52 pm |
backwater7
man thanks alot your right im about to pull out my hair! i got this thing done stuck it in the water it worked fine right off the bat then the more gas i gave it the slower it ran! i thought i was done with this thing!
Thu Mar 01, 2012 9:19 pm |
backwater7
Here are a few pics of the motor
Thu Mar 01, 2012 9:55 pm |
backwater7
idont have the finished pics yet but there coming
Thu Mar 01, 2012 10:30 pm |
SCmudder7071
That brace is gnarly looking! I like the vintage coke machine also
_________________ 1754 Extreme/LAProp Stage 2 GTR
Fri Mar 02, 2012 12:01 am |
sftull
I'm using a outboard transom mount on my build as well and have been struggling trying to fab up a trim system. The ob mount has holes for statics trim positions but I wanted to be able to adjust it on the fly. Any ideas as far as the trim and very nice build.
New GT Rig
Fri Mar 02, 2012 7:21 am |
backwater7
coke machine was put on the back burner for now i need to finish it soon! as far as the trim goes, man mine only works when i lift it out of the water. that was the only thing i didnt think threw. mine would have worked better if i had lowerd it 3''. i tried to copy copper head MM theres seems to work good. if you had anymore questions be happy to answer them!
Fri Mar 02, 2012 5:17 pm |
BlueShamu
Man that is awesome that you were able to fab up that motor! Best of luck with it. Let us know how it turns out.
Fri Mar 02, 2012 8:56 pm |
flyerfly
Joined: Fri Feb 18, 2011 12:06 am Posts: 24 Location: Alaska
Man I hope no one accidentally trips and falls on that brace...could really hurt !!
Thu Mar 08, 2012 1:31 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
_________________ so many rivers, so little time
Thu Mar 08, 2012 3:51 pm |
Quackkillz
Joined: Sun Dec 04, 2011 4:57 am Posts: 535 Location: Bottom of da boot
 HELP!!! Home build
I wish I had some helpful tips but I've never tried to build my own but it looks cooler then a polar bear's toe nail and I'm sure you'll get the bugs worked out soon....keep us posted, good luck!
_________________ 1648 weld bilt being followed by a 35 gtr
Fri Mar 09, 2012 5:48 am |
