It is currently Thu Jul 10, 2025 2:19 pm
Reply to topic  [ 7 posts ]
 pulleys and belts
Post pulleys and belts
could anyone tell me what type of belts and pulleys these SD motors require? would also appriciate if you could tell me where i can buy these parts any info would be great
Thu Mar 01, 2012 9:06 pm
Post Re: pulleys and belts
McMaster.com is a great sight to get pulleys. I bought my timing pulleys from there I think it was 18 tooth and 24 tooth for the gear reduction. I had to buy the hub also though so it would tighten on the shaft. I went with 1" belt width also.
14' aluminum can powered by a 16hp GDLT
Thu Mar 01, 2012 9:16 pm
man thanks alot, im glad you answered my post
Thu Mar 01, 2012 9:22 pm
I got h-100 timing pulleys on mine with qd bushings :P
Fri Mar 02, 2012 12:53 pm
I go straight to a Gates distributor. McMaster is usually about 10-15% higher cost. Use the Gates Design Flex software to outline your drive and then send that directly to a local distributor for a quote.
Fri Mar 02, 2012 3:01 pm
I agree mag10 mc master can be a little higher than other places. I got my pulleys from local outfit and they are top=TB16h100 kf-1 style and bottom=TB26h100 kf-1 for 1.63:1 gearing. I have also seen these pulleys on ebay and amazon at times. Also need to purchase the taper-lock bushings to go with this style pulley.
Fri Mar 02, 2012 3:34 pm
guys thanks so much everyone has been a big help
Fri Mar 02, 2012 5:06 pm
Users browsing this forum: No registered users and 40 guests
