Need a prop http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=29537 |
Author: | CrazyRaginCajun [ Mon May 28, 2012 7:45 pm ] |
Post subject: | Need a prop |
I have a 100lb pedal/paddle boat that well isnt much fun anymore lol After a ton of reading on here i decided to make a short tail. I have a honda copy 6.5hp, clutch (10 tooth) and a 14in jackshaft kit (3/4in with 3/32 keyway) with a 10 and 14 tooth sprockets. im not going to run shallow water, just rivers/small lakes/ponds and what not i cant pedal against or for as long as i need to. Any idea what prop will fit this shaft without too much trouble? |
Author: | BoatDR [ Tue May 29, 2012 9:34 am ] |
Post subject: | Re: Need a prop |
If you arent going to be in any shallow water, save yourself alot of headaches and just get a trolling motor. But if you are determied to make that motor work, I'm sure Copperhead or Dixie mudmotors would sell you a prop. |
Author: | CrazyRaginCajun [ Tue May 29, 2012 9:50 am ] |
the fish im going after need 2ft+ of water. i thought about the trolling motor route, as i have one but its old and pretty much doesnt work, and for the cost and aggravation of needing the battery, i really want to stick with that i have. if i could have found a lower/middle section from an outboard i could use a 6.5 vertical shaft i have. |
