homemade surface drive
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=30212
Page 1 of 3
Author:  CrazyRaginCajun [ Fri Jun 22, 2012 9:53 pm ]
Post subject:  homemade surface drive
homemade jobbie for river/pond/smooth lake fishing.
paddle boat, 6.5hp 10 tooth clutch, 14 tooth on the prop (have a 10 tooth to swap out)
6.5x4 weedless prop
3/4in keyway shaft (14in length)
1800rpm clutch, 2mph right when it engages. 4mph wide open (just under 3500)
what can i change to get a couple mph more?
Author:  cb5331 [ Fri Jun 22, 2012 9:55 pm ]
Post subject:  Re: homemade surface drive
Wow...
Author:  CrazyRaginCajun [ Fri Jun 22, 2012 10:02 pm ]
Author:  pokey79 [ Fri Jun 22, 2012 10:07 pm ]
WOW and strapped to the top of a town car!!!!!!
Author:  dfou [ Fri Jun 22, 2012 10:09 pm ]
Can we nominate this for photo of the month?
Author:  Team Camo [ Fri Jun 22, 2012 10:23 pm ]
Author:  redleg3316 [ Sat Jun 23, 2012 12:40 am ]
Somebody buy this man a beer!!!!
That is doing what ya gotta do fo sho!
Speed??? Well id change the hull for starters. :lol:
Author:  chaseh [ Sat Jun 23, 2012 1:00 am ]
Try a different prop
Author:  Nate [ Sat Jun 23, 2012 4:13 am ]
lol
Author:  CrazyRaginCajun [ Sat Jun 23, 2012 8:33 am ]
@ $135 for a prop, its going to have to stay.
if 4mph is all i get, then so be it. im going to try the 1:1 gear and see what happens today.
i had strange looks and some thumbs up when i took the interstate to go fishing (before the motor).
ol stinkin lincoln's paint has faded so it doesnt matter lol
i put a 302 long block in the truck with the upper intake off. very versatile car :lol:
Author:  swampbilly [ Sat Jun 23, 2012 5:50 pm ]
I bet u could peddle that boat at least 4 1/2 mph if u take the mm off the back of it. :lol:
Author:  redleg3316 [ Sat Jun 23, 2012 10:31 pm ]
I just looked at this pic again and started laughing so hard I cried!
Author:  Fletch [ Sat Jun 23, 2012 10:50 pm ]
I hear ya! Put duals on the back and drive it like you stole it!!
Author:  vertical_edge_800 [ Sat Jun 23, 2012 11:06 pm ]
LOL! I bet if you get some black death stickers that would put it at LEAST 15 mph.... I've always heard from people that built there own surface drives that there is a lot of tweaking with gear ratio and prop selection. Thats dedication... reminds me of the days when I had an 8' white inflatable with a 5hp merc outboard to go duck hunting with... what used to take me 2 1/2 hours to run now takes me less than 15 minutes.
Author:  barrelburner [ Sun Jun 24, 2012 7:08 am ]
That sea hawk sticker must mean it can fly :lol: :P :mrgreen:
Author:  CrazyRaginCajun [ Sun Jun 24, 2012 9:56 am ]
you guys are a trip.
Author:  Robn1020 [ Sun Jun 24, 2012 11:19 am ]
Good for you!!! Thats makin lemons into lemonade! :mrgreen:
Author:  JIMMY W [ Sun Jun 24, 2012 11:45 am ]
Make a 4 foot long exhaust pipe straight up with a flapper on it!
Author:  CrazyRaginCajun [ Sun Jun 24, 2012 12:43 pm ]
Author:  bayouboy2525 [ Sun Jun 24, 2012 1:04 pm ]
damn.. lol
should have went with a belt drive! wouldve had more speed
also should build a frame around the chain, it will add more speed becuse the durability for the shaft
Author:  autogateman [ Sun Jun 24, 2012 1:06 pm ]
heres a thought- the paddle thats under the boat thats attached to the pedals inside- maybe thats causing alot of drag
Author:  autogateman [ Sun Jun 24, 2012 1:07 pm ]
also-i see that auger prop, isnt that for a longtail??
Author:  CrazyRaginCajun [ Sun Jun 24, 2012 1:19 pm ]
Author:  autogateman [ Sun Jun 24, 2012 1:21 pm ]
No. Two different props. A lt prop is made to run submersed.
Author:  BoatDR [ Sun Jun 24, 2012 1:28 pm ]
I've seen a couple homemade motor frames come thru here, and I must say you get a A for effort on that one.
As far as why it wont run: 1) your chain (and metal plate in front of it) is about a foot and a half too long. Take a look at any of the belt drive/production models, the belt box is about 5"-6" above the bottom of the boat (and not draggin in the water, causing a disturbance to the prop). and 2) as Autogate man said that is the wrong prop. A longtail prop is made to run on a longtail (submerged and not geared down).
Author:  Goose Crumpler [ Sun Jun 24, 2012 2:09 pm ]
The picture of it on top of the car needs to be the picture of the month. Classic.
Author:  CrazyRaginCajun [ Sun Jun 24, 2012 2:17 pm ]
Author:  BROOKS [ Tue Jun 26, 2012 11:14 am ]
Well ~ The way I gots it figured ... you gittin' 0.62mph out of each HP .... PD gits 'bout 0.76mph from each ... Gator-Tail gits 'bout 0.85mph out of 'em .... course these are all stock style engines on the rite hull application ..... if'n you could up-grade hull .... you mite be surprised on yore results !!!!
BTW ~ Nice job !!! And yore rite 'bout the Towncar .... gots enuff turtle hull to stuff a D9 in !!!! :lol:
Author:  CJB [ Tue Jun 26, 2012 12:11 pm ]
Good job man, that's definately a first. That thing is kinda cute actually. And I'm sure it beats the hell out of having to paddle!
Author:  CootSlayerRMFT [ Tue Jun 26, 2012 12:49 pm ]
I just noticed the base is welded to C-clamps! :lol: :lol:
Author:  QuackStacker5253 [ Tue Jun 26, 2012 1:00 pm ]
Now I've seen it all!
Author:  JIMMY W [ Tue Jun 26, 2012 5:11 pm ]
Make damn sure you roll them windows up in your pimp mobile when you are launching your boat!!
Author:  CJB [ Tue Jun 26, 2012 6:37 pm ]
LOL
Author:  Buzz Killington [ Tue Jun 26, 2012 8:08 pm ]
Wow. Just wow.
Author:  vertical_edge_800 [ Tue Jun 26, 2012 8:52 pm ]
Is it strapped to the roof with the seatbelts looped through the doors?
Author:  CrazyRaginCajun [ Sun Jul 29, 2012 4:16 pm ]
Author:  waterfowl1 [ Sun Jul 29, 2012 7:22 pm ]
not bad at all. and at least you are getting a rooster tail out of it. :lol:
Author:  brasso [ Sun Jul 29, 2012 7:29 pm ]
Thats just plain awesome.
Author:  CrazyRaginCajun [ Sun Jul 29, 2012 7:31 pm ]
Author:  dguidry [ Sun Jul 29, 2012 7:34 pm ]
I'm thinking just a couple things about these videos: no parental supervision with big dreams; great combination for either sucess or disaster. You have had one of those "I have an idea" moments.
Page 1 of 3 All times are UTC - 6 hours
