It is currently Wed Sep 24, 2025 9:26 am
Reply to topic  [ 22 posts ]
 Pd stock prop
Post Pd stock prop
I did a search on tapatalk. Didn't find nothin. Is the 27hp stock prop a 12.25" prop like the 36hp is? They list em different on the site, not sure if that's cause a shaft differences or prop diameter though. Also it don't list the pitch.
Thanks y'all.
Sat Jul 07, 2012 6:30 pm
Post Re: Pd stock prop
i am pretty sure the diameter is the same..
I gave up mud motors
Sat Jul 07, 2012 6:40 pm
Theyre the same size i just had mine changed. What speed are u gettin?
36hp 3g PD on 17x48 Xseries PD boat - The Mud Scooter
Sat Jul 07, 2012 8:57 pm
Post Pd stock prop
A few weeks ago I was at 24-25. Now I'm at 22. I didn't change nothin and my bottom is fine. I measured the prop last night. It was at 11 and 15/16ths.
Sun Jul 08, 2012 5:07 am
Yea you need to get a new prop. What size boat you have and how much weight do you have in the boat with those speeds?
Sun Jul 08, 2012 9:48 am
Post Pd stock prop
It's an 1842 Alweld. Weight of boat is 360. I've got the bow mount trolling motor, an 80# deep cycle up front, a standard sized deep cycle in the rear with 6 gallons of gas, anchor and a few fishing poles.
Sun Jul 08, 2012 12:15 pm
I don't know if much has changed in the prop designs, but a 27 with some mild mods would spin the 32 prop. A 27 would not spin a 36 unless heavily modded. Been there done that.
Sun Jul 08, 2012 12:25 pm
Tue Jul 10, 2012 12:57 am
Post Pd stock prop
^^ maybe. Doubtful unless the prop has been changed. Need ta get more info from ya. Boat size, are ya maxed out on trim? What kind a load? What's the bottom a yer boat look like, beat up? Where's you're OOW RPM's set at?
Tue Jul 10, 2012 6:24 am
Where as the 32 and 36 has more of a dog ear and some tip curl.
Tue Jul 10, 2012 8:09 am
Tue Jul 10, 2012 12:20 pm
Post Pd stock prop
Polarkraft makes a lot of semi v hulls. Is this a flat hull or semi v? Also, if yet maxed out on trim that is more likely your issue.
Tue Jul 10, 2012 1:06 pm
It is a semi-v haul and it doesn't matter where i set the trim it doesnt get above 3400
Tue Jul 10, 2012 6:58 pm
Post Pd stock prop
It's a semi V hull. You ain't never gonna get more outa it. Get yerself a flat bottom. I had a 15' semi V. Only 3,400 RPM's max.
Tue Jul 10, 2012 7:22 pm
mitch...
i think they were all like that back in the day.. hopkins props
Tue Jul 10, 2012 7:53 pm
What kind of speeds are you getting now compared to before and what are your rpms now?
Tue Jul 10, 2012 9:59 pm
Post Pd stock prop
I got 18mph outa my 15' at 3,400 RPM's. Now with my 18' I get 3,800 and am runnin 24mph solid.
Wed Jul 11, 2012 5:25 am
well speed hasn't really been my problem. I ran 26 steady one day with pretty much no load and I run 22-24 with another guy and fishing gear but thats all with low rpms, I was wondering if i got my rpms up if id run even faster. that'd be great
Wed Jul 11, 2012 10:27 am
Post Pd stock prop
Higher rpm means faster prop turn so yes it should help with speed. I'm not attacking but fer a 27 pd those speeds sound way high fer those RPM's.
Wed Jul 11, 2012 11:45 am
If you are running those speeds, I wouldn't change anything. Especially if its decent out of the hole.
Wed Jul 11, 2012 11:50 am
Post Pd stock prop
Mitch,
Maybe my eyes not that good but I took a pic a my prop and it seems ta appear more like the 32 er 36 prop in comparing ta yer pics. What do ya think er anyone else fer that matter?
If it is a stock 27 prop, what am I missing ta compare it ta from yer first pic?
Wed Jul 11, 2012 12:59 pm
yea well I just dont understand why the rpms are so low. And I just replaced my prop, the guy said it didnt matter what size PD that they were all the same. Anyways- it looks like the one you have there.
Wed Jul 11, 2012 3:25 pm
