Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
Prop for Thai kit long tail 13hp
Just broke one of the aluminum props that came with the kit. It lasted 1 minute 30 seconds. Do all the longtails use the same shaft size? Can you guys recommend a pitch? It's on a riveted 1542 Jon with 900 lbs. I don't need speed at all because the furthest I will go is 1 mile. I am running in tons of vegetation with 1 foot or less of water.
_________________ 23 swomp/ 1542 tracker
Thu Aug 09, 2012 9:18 am
Woodiebuster
Re: Prop for Thai kit long tail 13hp
What kind of shaft is it?
3/4" x 10tpi is the industry standard.
