It is currently Thu Jul 10, 2025 2:51 pm
[ 3 posts ] |
brock2013
Joined: Sun Aug 12, 2012 1:04 pm Posts: 35 Location: Brock TX
 Shaft housing
Where do you get shaft housings? Or do you make them yourselfs? How do you make the housing so the bearings fit?
Mon Aug 20, 2012 10:43 pm |
Sgt Griz
Joined: Sun Aug 12, 2012 8:55 pm Posts: 3 Location: Minnesota
 Re: Shaft housing
Made it 1 1/4 DOM tube three brass bushings 1 in OD 3/4 in ID may have to sand down the out side a little so the fit but not to much drill and tap your tube in the center and 2.5 in from the ends two holes per bushing I taped mine in 1/4 28 place your brass with a wood dowell seals came from carquest again 1 in OD 3/4 in ID your set screws for your bushings should be about 45 degrees apart drill and tap two extra holes for your grease nipples drill and t tap all holes before placing brass
_________________ You can't fix stupid but you can at least try and cut it off at the pass
Tue Aug 21, 2012 1:13 am |
brock2013
 Re: Shaft housing
Do you have any pictures of it?
Wed Aug 22, 2012 9:01 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 31 guests |
