It is currently Wed Sep 24, 2025 6:43 am
Reply to topic  [ 8 posts ]
 shaft keyway
Post shaft keyway
Ok so I got nearly everything machined for my home build. Only thing left is cutting the keyway where the sprockets attach. I was just wondering what size keyway I need in it. The sprocket is from McMastercarr.com. It has a 3/4" bore but just says standard ANSI keyway.
14' aluminum can powered by a 16hp GDLT
Wed Sep 12, 2012 6:29 pm
Post Re: shaft keyway
Maybe measure the depth of the keyway on the sprocket.
Thu Sep 13, 2012 7:34 am
With a .750" bore, it will typically be a .1875" key. I would just buy the sprocket bushing and measure it to be sure.
Thu Sep 13, 2012 11:43 am
I already oredered the sprocket I'm just waiting for it to come in the mail. I'm just trying to get the machining done so when it gets to the house I will have everything I need to start assembling. I guess I'll have to wait till it gets here to mill the keyway.
Thu Sep 13, 2012 10:25 pm
Should say where ya ordered it from
Wed Sep 19, 2012 6:29 pm
Wed Sep 19, 2012 6:51 pm
I hear ya on those brown truck blues. I get them everytime I order anything. I'm sure they have a customer service or tech support line that you could call in the mean time to satisfy your itch...
Wed Sep 19, 2012 6:58 pm
For 3/4" shaft a standard ANSI key will be a 3/16x3/16 or 1/4 by 1/4.
If 3/16" your keyway cut in shaft needs to be
width
min .187" max .188"
depth
min .107" max .113
if 1/4" key
width
min .249" max .250"
depth
min .142" max .148
Thu Sep 20, 2012 5:59 am
