It is currently Wed Apr 24, 2024 2:06 pm
Reply to topic  [ 16 posts ]
 Lower units ? = everything made by the MM Mfg.
MMT Moderator
Post Lower units ? = everything made by the MM Mfg.
everthing but engine questions go here.
thanks
duck wacker
Sun Jul 19, 2009 12:07 am
New Member
Post Re: Lower units ? = everything made by the MM Mfg.
What's the typicall gear reduction ratio on surface drives
Fri Feb 04, 2011 3:05 pm
If an engine ran constantly at 3500 rpms and the reduction is a 2:1. The prop is a 9x6. The known hours on the motor are 892.4 assuming you travel the atchafalya river how many times would one make it to myette point to berwick and back? Part B) How much gas will you burn? Part C) How much beer does that take?
17*38 Klibert 23GDLT
Fri Feb 04, 2011 3:55 pm
Fri Feb 04, 2011 4:03 pm
New Member
Checked lower unit oil last night and realized it was pretty much all milky. Drained it and replaced it . I'm guessing my seal is bad , is this covered under warranty ? PD 36 - purchased October 2010.
Sun Apr 24, 2011 6:17 pm
I am going to repost my question in this thread.
Well have done some lurking on here and other forums and have run into a question. On the gear ratio of a belt driven sd. 18 Kohler magnum,hill 10x8 prop,1542 lowe. How many teeth on the engine and how many teeth on the bottom would be ideal for some of you that have built you own or messed with the gearing on sd's. Thanks for any input. Let us Know if we left somthing out.
Sun Jul 08, 2012 12:31 pm
Im running 36 top 44 bott = 1.22. on a 10x6 I think im near 18 HP ?
1.5 may work better
Hope that helps you.
Tue Oct 23, 2012 5:43 pm
I run 10 x 8 props with a Robin 14 HP at 1 1/2 to 1 reduction. For 18 HP I would probably bump it up to 10 x 10 for starters.
Mark F. Cheney
on the Great Salt Lake marsh
Thu Sep 12, 2013 2:21 am
branston0311 mine is a 2011 36hp pd and i had the same problem with mine and i called pd and was told that if you back the boat in the water to fast at a steep launch water would enter the vent and go inside the gear case.
Tue Dec 17, 2013 7:22 pm
look at the date bro
Tue Dec 17, 2013 7:25 pm
All the posts on this thread are at least months apart. Wtf?
Tue Dec 17, 2013 7:41 pm
I'm trying to put grease in that grease zero under the Allen screw plug on my lower unit and grease doesnt go into it I pulled the grease zero off and grease comes out it but when I put the zero back in and try to grease it . The grease still dsnt go into lower unit what do I do it just started making noise when i put into gear.
Mon Jan 27, 2014 8:47 pm
Bad zerk
''It's just 90 foot you're gonna die if you fall 20 foot so whats another 70 foot'' Jason Humble climbing school 12'
Tue Jan 28, 2014 9:43 am
Tue Jan 28, 2014 9:44 am
Even though I pulled the zerk out and put it on the grease gun and grease came out of the zerk? What made me check it out is I got my buddy to change my lower unit oil and after I went run it and now when I put the boat in the water and put it in gear it's making a we are sound almost like a electric motor friction noise behind that grease zert so I'm worried that maybe I didn't have enough grease in there? Wat do I do should I try a new grease zerk maybe
Tue Jan 28, 2014 3:48 pm
Post Re: Lower units everything made by the MM Mfg
Eat - Sleep - Hunt ! ! !
Sat Oct 19, 2019 4:43 pm
Users browsing this forum: No registered users and 160 guests
