Grass on prop http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=34652 |
Author: | rudyeng [ Sun Nov 25, 2012 9:16 pm ] |
Post subject: | Grass on prop |
My mud motor has a 1/4” gap from the prop to the bushing. Grass always gets tangled up in that area. Always have to clear it out. Is that normal ? Should I add a washer to fill the gap ? |
Author: | UNCLE-J [ Sun Nov 25, 2012 9:18 pm ] |
Post subject: | Re: Grass on prop |
Just put it in reverse , then back in forward. It will clean it out |
Author: | ironman_gq [ Thu Nov 29, 2012 9:09 am ] |
does it wrap up in there and then clog up the prop? I had a similar problem with my LT, took som 1/8" plate and welded it to the skeg so it had very little clearance to that gap, it acted like a shear and cut anything that started to get wrapped up. |
Author: | rudyeng [ Thu Nov 29, 2012 10:32 am ] |
Yes. I was going to add an oversized washer and sharpen the edges so it would cut it but I think your idea will work better. |
Author: | Kmoppert [ Thu Nov 29, 2012 11:10 am ] |
Author: | Shane77624 [ Sun Dec 09, 2012 5:01 pm ] |
Author: | marsh mule [ Sun Dec 09, 2012 5:47 pm ] |
Author: | fowlmouthed_hunting [ Sun Nov 20, 2016 8:35 pm ] |
IU am having the same problem. It sounds like most say the skeg should be closer to the prop. I guess I will try making a new skeg and seeing how that does with the grass. |
Author: | CypressCritter [ Fri Nov 25, 2016 9:34 am ] |
A little grass there shouldn't affect anything, and reversing should clear most of it. Now nylon fishing line or trot line string that with do a number on your seals!!! Get it out asap!!! |
Author: | MNGunner [ Fri Nov 25, 2016 9:44 am ] |
