Delta Goose
 27hp PD prop
Which prop do you use and how do you like it.
Tue Feb 12, 2013 3:17 pm |
cb5331
 Re: 27hp PD prop
I ran the 2 blade for the 32 on my 27. It was a little slow out of the hole, but I could carry a load closer to my empty speeds. They offer a 3 blade for it now that they didn't offer back then, most guys I've seen with it are happy. Better hole shot and load carrying, not quite as good in the slop. What kind of conditions do you run most of the time?
Tue Feb 12, 2013 7:59 pm |
renovator
 Re: 27hp PD prop
I got a worn 36 prop u can have that may be just what you're looking for!!
_________________ 1648 gd hull flying in front of a stage 3 with fpr
Tue Feb 12, 2013 8:25 pm |
cb5331
 Re: 27hp PD prop
Tue Feb 12, 2013 8:32 pm |
renovator
 Re: 27hp PD prop
Its only missing about 1/4" off each blade. Free of charge
Tue Feb 12, 2013 8:37 pm |
cb5331
 Re: 27hp PD prop
 You can send it to me if you just want to give it away. It needs the cup to work properly. Just putting a worn out prop from a larger motor on a smaller motor isn't gonna get him what he needs. You lose all the "push".
Tue Feb 12, 2013 8:42 pm |
renovator
 Re: 27hp PD prop
Yep I was turning plenty rpm's but no speed
Tue Feb 12, 2013 9:00 pm |
Delta Goose
 Re: 27hp PD prop
I run everything on the lake I hunt thick mud, shell beds, gravel and sand bars. I've ran GD and MB motors on the lake this is my first PD. What size is the 27 hp prop? and where can you get the 3 blade at I've looked at the hopkins web site just didn't what size to get.
Wed Feb 13, 2013 2:59 pm |
TX Aggie '06
Joined: Mon Jul 26, 2010 4:32 pm Posts: 684 Location: Houston TX
 Re: 27hp PD prop
From PD...?
Sent from my MB865 using Tapatalk 2
Wed Feb 13, 2013 3:04 pm |
Delta Goose
 Re: 27hp PD prop
Yea I've looked at the web site just order some parts from them just didn't know what everybody was having the best luck out of before I bought a new prop.
Wed Feb 13, 2013 3:07 pm |
cb5331
 Re: 27hp PD prop
Call pd.
Wed Feb 13, 2013 3:09 pm |
Delta Goose
 Re: 27hp PD prop
Thanks I'll call PD
Wed Feb 13, 2013 3:12 pm |
renovator
 Re: 27hp PD prop
Pd is very helpful and will have you going in the right direction. Just tell them all of the conditions and your setup.
Wed Feb 13, 2013 7:15 pm |
gatorkiller1967
 Re: 27hp PD prop
3 blade best on 27 Call Hopkins
Fri Feb 15, 2013 3:47 pm |
