It is currently Mon Sep 22, 2025 2:15 pm
Reply to topic  [ 24 posts ]
 STAGE 1 PROP QUESTION
Post STAGE 1 PROP QUESTION
Fella's,
I am running a new prop on a stage 1 PD. I am wondering if anyone has changed from a factory prop to a 12X14 cleaver. If so, How many RPM's did you loose?
ANY HELP WOULD BE MUCT APPRECIATED...
Wed Aug 12, 2009 8:12 pm
Post Re: STAGE 1 PROP QUESTION
i got a 2054 and had a 12x14 with light tip curl and it was a beast could rap it up as much as i wanted.....also got a 12x14 with heavy tip curl and i could not get over 4K rpm
Wed Aug 12, 2009 8:17 pm
you running a stage 1?
Wed Aug 12, 2009 8:23 pm
Mathmatically assuming you could run both at 30 mph - there is a 567 rpm reduction in engine rpms on the 12x14 versus the 12x12....
Real world - 12x14 is a dang big blade to sling with any MM....
Wed Aug 12, 2009 8:25 pm
Thanks...
I am turning EXTREMELY Too many RPMS with my factory prop.. With about 1K #'s I am running at 32mph BUT>>>> I am turning 4350 to 4450 RPMS... I have a rev limiter, but was told that it isnt going to kick in until around 4800. I can by the 12x14 cleaver right now. Opinion???
Wed Aug 12, 2009 8:28 pm
I am running a 12x13 Hopkins on my stock 36 at 3750 rpms and 28mph.If this helps any.
Wed Aug 12, 2009 8:32 pm
Wed Aug 12, 2009 8:36 pm
Lots of "subtle" science in prop design - like Bdog was sayin'
If they had a return option it would make the testing less expensive
you might try to borrow one first.
Wed Aug 12, 2009 8:43 pm
i ran a stage 1 on my boat for 20 hrs or so and loved my first hopkins with slight tip curl....the new pop has more botom end but it droped my rpms alot
Thu Aug 13, 2009 4:49 am
Pro Drive m'fers
Thu Aug 13, 2009 7:15 am
dont say that.....im tryin not to get FE marit badge until i have 10000000000 post
Thu Aug 13, 2009 8:49 am
Does anyone have a prop other than that of a factory prop that I could make a run with? I really need to purchase one, but unsure as to which one.
Thu Aug 13, 2009 11:34 am
Pro Drive m'fers
Thu Aug 13, 2009 12:33 pm
basin,
i need you to quote me a rental charge on making a run with your prop...
Fri Aug 14, 2009 8:41 am
Pro Drive m'fers
Fri Aug 14, 2009 9:10 am
you got stage 1?
Fri Aug 14, 2009 9:11 am
Yep
Pro Drive m'fers
Fri Aug 14, 2009 9:12 am
Basin,
How many RPMS do you turn while running full throttle?
Fri Aug 14, 2009 9:23 am
Stock prop I can turn 4650-4700 if I wanted to but of course I won't turn it that high.
Pro Drive m'fers
Fri Aug 14, 2009 9:27 am
Yeap.. Thats defently the same RPMS
Fri Aug 14, 2009 9:31 am
UJ, I have a 12x13 tulip that your more than welcome to try also. I'll be up that way Sun or Mon.
Fri Aug 14, 2009 7:09 pm
18x48 Charles Leonard / 36PD
Fri Aug 14, 2009 7:12 pm
:lol: I bought it from Giga, it came off a GDSD. He said it doesn't need that extra blade! :lol:
JK :lol: Man, I wish I still had that prop, It was a preformer. I hit 31mph in my tub with that thing! with just a Mukuni carb! little to no prop slip at all.
Nah, Its Willets old/but still brand new prop only used a couple times. and yes it does have two blades. lol
Fri Aug 14, 2009 7:50 pm
well at least you got a motor to run it on right now. :cry:
Fri Aug 14, 2009 8:11 pm
