STAGE 1 PROP QUESTION
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=3889
Author:  UNCLE-J [ Wed Aug 12, 2009 8:12 pm ]
Post subject:  STAGE 1 PROP QUESTION
Fella's,
I am running a new prop on a stage 1 PD. I am wondering if anyone has changed from a factory prop to a 12X14 cleaver. If so, How many RPM's did you loose?
ANY HELP WOULD BE MUCT APPRECIATED...
Author:  Brinkleydog [ Wed Aug 12, 2009 8:17 pm ]
Post subject:  Re: STAGE 1 PROP QUESTION
i got a 2054 and had a 12x14 with light tip curl and it was a beast could rap it up as much as i wanted.....also got a 12x14 with heavy tip curl and i could not get over 4K rpm
Author:  UNCLE-J [ Wed Aug 12, 2009 8:23 pm ]
you running a stage 1?
Author:  Gigafowl [ Wed Aug 12, 2009 8:25 pm ]
Mathmatically assuming you could run both at 30 mph - there is a 567 rpm reduction in engine rpms on the 12x14 versus the 12x12....
Real world - 12x14 is a dang big blade to sling with any MM....
Author:  UNCLE-J [ Wed Aug 12, 2009 8:28 pm ]
Thanks...
I am turning EXTREMELY Too many RPMS with my factory prop.. With about 1K #'s I am running at 32mph BUT>>>> I am turning 4350 to 4450 RPMS... I have a rev limiter, but was told that it isnt going to kick in until around 4800. I can by the 12x14 cleaver right now. Opinion???
Author:  coastal [ Wed Aug 12, 2009 8:32 pm ]
I am running a 12x13 Hopkins on my stock 36 at 3750 rpms and 28mph.If this helps any.
Author:  UNCLE-J [ Wed Aug 12, 2009 8:36 pm ]
Author:  Gigafowl [ Wed Aug 12, 2009 8:43 pm ]
Lots of "subtle" science in prop design - like Bdog was sayin'
If they had a return option it would make the testing less expensive
you might try to borrow one first.
Author:  Brinkleydog [ Thu Aug 13, 2009 4:49 am ]
i ran a stage 1 on my boat for 20 hrs or so and loved my first hopkins with slight tip curl....the new pop has more botom end but it droped my rpms alot
Author:  basinhunter [ Thu Aug 13, 2009 7:15 am ]
Author:  Brinkleydog [ Thu Aug 13, 2009 8:49 am ]
dont say that.....im tryin not to get FE marit badge until i have 10000000000 post
Author:  UNCLE-J [ Thu Aug 13, 2009 11:34 am ]
Does anyone have a prop other than that of a factory prop that I could make a run with? I really need to purchase one, but unsure as to which one.
Author:  basinhunter [ Thu Aug 13, 2009 12:33 pm ]
Author:  UNCLE-J [ Fri Aug 14, 2009 8:41 am ]
basin,
i need you to quote me a rental charge on making a run with your prop...
Author:  basinhunter [ Fri Aug 14, 2009 9:10 am ]
Author:  UNCLE-J [ Fri Aug 14, 2009 9:11 am ]
you got stage 1?
Author:  basinhunter [ Fri Aug 14, 2009 9:12 am ]
Yep
Author:  UNCLE-J [ Fri Aug 14, 2009 9:23 am ]
Basin,
How many RPMS do you turn while running full throttle?
Author:  basinhunter [ Fri Aug 14, 2009 9:27 am ]
Stock prop I can turn 4650-4700 if I wanted to but of course I won't turn it that high.
Author:  UNCLE-J [ Fri Aug 14, 2009 9:31 am ]
Yeap.. Thats defently the same RPMS
Author:  bayouboy [ Fri Aug 14, 2009 7:09 pm ]
UJ, I have a 12x13 tulip that your more than welcome to try also. I'll be up that way Sun or Mon.
Author:  POKER1 [ Fri Aug 14, 2009 7:12 pm ]
Author:  bayouboy [ Fri Aug 14, 2009 7:50 pm ]
:lol: I bought it from Giga, it came off a GDSD. He said it doesn't need that extra blade! :lol:
JK :lol: Man, I wish I still had that prop, It was a preformer. I hit 31mph in my tub with that thing! with just a Mukuni carb! little to no prop slip at all.
Nah, Its Willets old/but still brand new prop only used a couple times. and yes it does have two blades. lol
Author:  POKER1 [ Fri Aug 14, 2009 8:11 pm ]
well at least you got a motor to run it on right now. :cry:
