It is currently Fri Jul 11, 2025 6:19 am
Reply to topic  [ 25 posts ]
 Yikes! leak! help
Post Yikes! leak! help
I have no clue whatsup help.
36hp 3g PD on 17x48 Xseries PD boat - The Mud Scooter
Sun Apr 21, 2013 3:33 pm
Post Re: Yikes! leak! help
drain it and check your bottom shaft seals... most likely the shaft seals are out and got water in it and pushed oil out the vent
I gave up mud motors
Sun Apr 21, 2013 3:36 pm
Drain lu oil? I have no clue what any of that is. Thanks for the input, but is there anyway i can find a diagram or can u elaborate with pictures or something? Thanks a lot
Sun Apr 21, 2013 3:49 pm
the allen head screw on the left side of the gear box is the fill hole
same side at the bottom of the shaft there is another plug
pull the top plug
pull bottom plug
drain oil
Sun Apr 21, 2013 4:05 pm
Yea ive changes the lower unit oil before but im not sure what seals you are talking about. Im guessing you mean the allen plugs?
Sun Apr 21, 2013 4:08 pm
the stainless steel nut at the bottom of the shaft in front of the prop has 3 seals inside of it
you can order a new one with seals from prodrive and send them your old one with the bad seals back
it is left handed threads
Sun Apr 21, 2013 4:19 pm
You mean that big nut? Id have to take rhe prop off right?
Sun Apr 21, 2013 4:40 pm
Sun Apr 21, 2013 4:42 pm
Ok so once i take it off, what am i looking for to see if the seals are ok? And what do these seals look like?
Sun Apr 21, 2013 4:48 pm
When water gets in the LU 99.9% of the time its just the seals needing to be replaced. The other .1% your shaft is worn, or your housing is cracked. Change the seals.
Sun Apr 21, 2013 5:10 pm
Thanks so much guys. So how much are they and what are other signs of having bad seals? Also, what would happen if i ran the motor with bad seals?
Sun Apr 21, 2013 5:40 pm
Youd get contaminated lu oil
B. MacDonald
Sun Apr 21, 2013 7:10 pm
Mon Apr 22, 2013 5:00 am
Yea mines is a 2010, so if i give them the nut they replace it for free? Does anyone know if h&h would do the same?
Mon Apr 22, 2013 6:18 am
HOTSAUCE170 wrote:
Mon Apr 22, 2013 6:47 am
Mon Apr 22, 2013 9:01 am
[quote="MarshMan985"]Yea mines is a 2010, so if i give them the nut they replace it for free? Does anyone know if h&h would do the same?[/quote
Not sure what you have but remove the nut. The seals look similiar to rubber o-rings. The new nut will have three. They can be removed from the nut. If your nut has three in it, then you have the new style. Then there would be no reason to have the nut replaced. If it only has two seals, then you have old and the nut must be swapped out. All they are going to do is machine it out to allow for a third seal. If you already have the new version, then just order the seals, there about a couple bucks. H&H in houma might have just the seals.
Mon Apr 22, 2013 11:03 am
H and H carries just the seals. If you don't know what you are doing its a PITA to press the seals in the nut. They bend very easy. Ask me how I know.
Mon Apr 22, 2013 12:28 pm
Thanks a lot guys. So if they are regular o rings, how can i tell if they are bad? Are they gonna be torn? Also, cant i just replace them with o rings from lowes? Or are these special?
Mon Apr 22, 2013 2:35 pm
Mon Apr 22, 2013 2:48 pm
Mon Apr 22, 2013 2:59 pm
Thanks guys. So one person said $70 and someone else said just a few... which is true( i will find out tomorrow anyway) just curious.
Mon Apr 22, 2013 6:18 pm
Tue Apr 23, 2013 5:27 am
70 bucks for a nut with new seals when you give them your old one
be sure to cut grass from around the prop after every run(if you dont do so)
I run so many lillies and grass that I'd cut brand new seals in a weekend... just keep fresh oil in it.
if its a problem you could get your lower unit worked on by PD and they can do the grease filled shaft like all the new ones.
Tue Apr 23, 2013 6:48 am
How much would it cost to get PD to switch the shaft to the grease filled shaft instead of the oiled?
Wed May 01, 2013 8:23 pm
Users browsing this forum: Google [Bot] and 32 guests
