It is currently Fri Jul 11, 2025 6:27 am
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 Prodrive Skeg and Cavitation Plate Modded
Post Prodrive Skeg and Cavitation Plate Modded
I run mostly in heavy grass, lilies, vegetation, etc... and have cut enough crap from the shaft to build a tiki hut so I gots me some goodies from ole bayouboy 8-)
I'm a little ahead by posting before trying it out but it's got to work better :lol: Went with his skeg with the pressed torque tab and a weed cutter. Top notch work I should say!
Before (old picture, did not remove to change skeg and mod plate, simply for comparison)
Finished up with a little rattle can.
Mon May 20, 2013 9:18 am
Post Re: Prodrive Skeg and Cavitation Plate Modded
go run it!
I gave up mud motors
Mon May 20, 2013 9:20 am
Looks good and bayouboy definitely does good work!
I like your idea with the kicker on your cavitation plate extended above the shaft.
Jesse
27 PD FPR 16x36 skiff - aka - DITCH WITCH
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Mon May 20, 2013 9:26 am
What happens when the prop tightens down on the bushing some more? The prop looks awful close to the weed cutter.
Mon May 20, 2013 9:29 am
Mon May 20, 2013 9:37 am
Of course you have to have enough clearance, but if your grass blocker doesn't work well enough, you could add a tit like pictured...
Jesse
Mon May 20, 2013 9:39 am
Mon May 20, 2013 9:41 am
Mon May 20, 2013 9:43 am
I don't o well...
Mon May 20, 2013 9:45 am
Just recently got all the same stuff from bayouboy. You going to like it you won't ever go back to the stock one
Mon May 20, 2013 9:49 am
You right. It's hard to see but looks like something is there...
Will- keep it up and before long your motor will look like this:
Jesse
Ha, building mine for purpose, not looks... less than a minute with OD green rattle can for me!
Mon May 20, 2013 9:53 am
You'll like it. I find that logs and other skeg hits are less violent with it. If you hold your stock skeg up to BB's it's about 1 1/2" shorter (height wise), which makes for less contact area when running WOT. I actually picked up 18mph just by adding it... Gonna put some gator glide on it soon to get an extra 3mph.
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Mon May 20, 2013 10:12 am
It definitely gots teef!
Mon May 20, 2013 10:20 am
Lol daaang!
Jesse
Mon May 20, 2013 10:21 am
I don't know if I want it going any faster! I have to slow down now at night to let the light get back in front to see where I'm going!
Mon May 20, 2013 10:22 am
On installation, I recommend that you set it 1/16 or 3/32 from the prop. On a new prop install put the cutter all the way forward for a few runs before resetting it to the distance posted above. Also check it from time to time especially after a hard prop strike. Hole is slotted and The edges are beveled, Been running them for years now and found if the prop does touch it just pushes it forward and the beveled edges at as a wear plate. ( worn in a few seconds ). Flatboat is probably coming close to having the most hour on one. And after a few minutes of sharping with a small dremel its like new again.
View of slot
Mon May 20, 2013 10:33 am
Gotcha. Was just noticing that he had quite a bit of bushing still sticking out the prop, and remembered my bushing always ended up flush with the prop or slightly inside it.
Mon May 20, 2013 10:44 am
Mon May 20, 2013 10:45 am
^ :lol:
Mon May 20, 2013 10:59 am
whats the advantage of the floating cavitation plate?
Mon May 20, 2013 11:42 am
Mon May 20, 2013 12:06 pm
Mon May 20, 2013 3:25 pm
Mon May 20, 2013 3:28 pm
Why's that funny? A lot of them church girls are easy! And them farmers daughters!!! well you know!
Mon May 20, 2013 3:30 pm
Will, What's going on with the spline in the old pic of your LU?
Mon May 20, 2013 3:57 pm
Mon May 20, 2013 4:05 pm
Gotcha, Sorry you got your hole plugged.
Mon May 20, 2013 4:24 pm
1850 & 36pd
Mon May 20, 2013 4:34 pm
Bayou Boys skeg will allow you to dig 6" deeper and run 4 mph faster
Mon May 20, 2013 4:56 pm
Mon May 20, 2013 5:01 pm
Mon May 20, 2013 5:29 pm
Mon May 20, 2013 5:38 pm
Did I miss something? Snappy? Really? Snappy?? More like a CRAPPY come back! :lol:
Mon May 20, 2013 5:45 pm
Here is what a saws all and about 7 beers did to mine
Mon May 20, 2013 6:40 pm
Damn. :lol:
Mon May 20, 2013 6:46 pm
That's what I'm talkin bout!!! :lol:
Mon May 20, 2013 8:28 pm
I did that about to years ago. I forgot how it ran prior to the saws all modifications
Tue May 21, 2013 6:47 am
i need to cut my spare one
Tue May 21, 2013 6:54 am
Users browsing this forum: No registered users and 33 guests
