PD Lower Unit Grease
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=41447
Author:  Wilson [ Wed Jun 05, 2013 6:53 pm ]
Post subject:  PD Lower Unit Grease
How often do you grease the newer style Prodrive lower units? Specifically the zero right above the cav plate that makes grease come out by the prop.
Author:  T-Bubba [ Wed Jun 05, 2013 7:38 pm ]
Post subject:  Re: PD Lower Unit Grease
i grease mine often.. i run alot of lillies that get stuck around the prop and cut the seals
every time i pump grease water comes out... even after the first ride
Author:  K'jun [ Wed Jun 05, 2013 8:17 pm ]
This is a stupid question, but do you pump in that grease sert till grease comes out by prop? If not how many shots do you pump in at a time?
Author:  T-Bubba [ Wed Jun 05, 2013 9:35 pm ]
i pump it till grease comes out a good bit to flush it
Author:  Will [ Thu Jun 06, 2013 3:41 am ]
Author:  K'jun [ Thu Jun 06, 2013 6:26 am ]
So I'm assuming here, theres no seal around the prop shaft that will be blown out if i keep pumping grease till i see it?
Author:  Will [ Thu Jun 06, 2013 6:28 am ]
Correct
Author:  pooldoo73 [ Thu Jun 06, 2013 2:01 pm ]
There are seals around the prop shaft, but they won't get blown out when u squeeze it.
Author:  bayouboy [ Fri Jun 07, 2013 10:17 am ]
I purge mine every 50 hrs or so, by removing the bottom plug on the prop shaft and pump grease until it comes out clean.
