It is currently Mon Sep 22, 2025 4:33 pm
Reply to topic  [ 3 posts ]
 Power Trim on PD
Post Power Trim on PD
Had to replace one of my lines hydrolic trim of the pd....I didnt "purge" (i guess thats what you call it) the line once I got one end on and after I put the other end on and ran it a couple of times I realized it. (Sorry if this doesnt make much sense...Im kinda drunk). So Im sure I got some air in the lines...any way to get rid of it? It works fine...just a little noisy...also where do you add fluid...I had quiet a few drops leak out before I got the new line....any way to check the level???
thanks bros....Shafer
WC 1848 Bateau w/ 36 PD FPR
Sun Aug 30, 2009 6:30 pm
Post Re: Power Trim on PD
I replaced a hydro line on mine a couple weeks ago. Make sure the lines are tight. I was told by Peck to trim it up and down a few times and you should be good to go. I didnt have any trouble. There is a flat head screw, the head is about the size of a dime on the hyrodaulic pump on the front middle way down. Thats where you add it. The screw is also a dipstick so you can check to see how much fluid you have.
Sun Aug 30, 2009 6:47 pm
And the cap/dipstick where you add fluid is a good spot to purge out the air. Leave it slighlty cracked and work the trim up and down and it should be fine.
Sun Aug 30, 2009 8:13 pm
