It is currently Sat Sep 20, 2025 11:42 pm
Reply to topic  [ 40 posts ]
 PD Anti-Kickback Bar Removal
Post PD Anti-Kickback Bar Removal
Hope this thread is in the right forum . . . .
A year ago I added the power T&T to an '05 32PD. Followed the directions to a "T", but in the end had to make a modification to the anti-kickback bar (that's what I'm calling it - prior to power T&T it as the rod with a link on it to lock the motor in the raised position).
When I added the T&T, the bar interfered with the new, larger rollers. Quite a bit of interference - 1/2". Mistakenly I cut the bar off - a real PITA, since it is stainless. After running like this last season, I now realize that the bar should have remained, albeit modified. Now I need to remove the remains (about 4") of the bar. I removed the set screws, but am having a real issue with removing the bar. Can't drive it down, as it will hit a portion of the lower unit casting, and driving it up is a PITA as well as the bar is peening over.
Any help? I looking at potentially removing the power head to get more room to work. Possibly welding a heavy bar perpendicular and then using that to drive against.
Wed Sep 02, 2009 9:29 am
Post Re: PD Anti-Kickback Bar Removal
I broke one off and had to get that piece out it was about 4" and a BIATCH..This is what i did...
Stand back and look at it.Call it a MF,Whore,Fuking Piece Of Shiat..Make sure the set screw is removed.Find a drift or piece of bar that will fit in from the bottom and start whacking with a 5lb or 10lb sledge hammer.Stan back and tell it..Yeah you MF your moving now Biatch and then go back to swinging.It will come out..You just have to call it the right name.When i drove the new one in it was so tight i had to put some KY on it.
Good Luck!!!
Wed Sep 02, 2009 9:44 am
Wed Sep 02, 2009 9:45 am
Pro Drive m'fers
Wed Sep 02, 2009 9:49 am
yank the powerhead and drop the lower unit. should take less than an hour. then take the tower off the transom mounting bracket. then it will be alot easier to drive out from the bottom. I broke off one of my bars one time, hitting stumps.
24x60 Dual Prodrives
Wed Sep 02, 2009 10:54 am
:lol: :lol: :lol:
Wed Sep 02, 2009 10:59 am
Wed Sep 02, 2009 12:32 pm
i REALLY like da way coastal works... and def. some funny shiat
Wed Sep 02, 2009 12:34 pm
Wed Sep 02, 2009 12:36 pm
after you yank powerhead, drop lower unit (by taking out 4 or 6 bolts), and take off the reverse plate that's just sitting there...... the tower is the round pipe looking thing that the top of the lower unit turns in. it's been a while since I've done it, but I'm pretty sure there's just one big pin that goes through. this is actually what holds the motor on the transom bracket, and allows the motor to pivot up and down. i'm sure you'll figure it out when you go home and look at it.
Wed Sep 02, 2009 2:06 pm
Got home and got everything unbolted to the point that the powerhead can be pulled. Looked over the rest of the scenario and believe I understand the process Crews laid out. I'm assuming that the lower unit bolts (4ea) are the smaller bolts (11-12mm hex head) and the rest of the bolts (13mm or so hex head) are the reverse plate bolts . . . .
Since I'm doing this myself, I also cut a couple of wedges from a 2x6 that can be driven between the motor plate and reverse plate, in hopes that it will help the separation process a little. (I do have a hoist for the primary lifting.) Once I have the transom tower separated I'm hoping I can fanagle it in a press and press the kickback bar remains out.
Of note, I stopped by Mudd's (Extra Mud) and took a look at a couple of the PDs he has mounted. Interestingly enough all of the PDs he had have 2 kickback bars, one short, one longer, whereas mine only has (had) one, and no hole in the casting for another. Wonder if I should cal PD and see what the 'upgraded' tower for a LS PD runs ($$$) ?
Wed Sep 02, 2009 7:21 pm
dude... u ain't gotta take it all apart like dat. Do like Cope said and just beat it out from da bottom usin a few kind & gentle words. lol
Wed Sep 02, 2009 7:39 pm
I wouldn't spend the money on a new one unless you break it. You will be fine.
18x48 Charles Leonard / 36PD
Wed Sep 02, 2009 7:41 pm
Wed Sep 02, 2009 8:31 pm
Thu Sep 03, 2009 5:44 am
my 27 had 1 bar instead of two. so I just took the tower off, and sent it to ProDrive. they fixed it all up for me, and sent it back. then I put it all back together. I'm just trying to help this fella out. do what you want to do.
Thu Sep 03, 2009 5:57 am
Thu Sep 03, 2009 6:03 am
Thu Sep 03, 2009 7:24 am
why doesn't he just take the tower off, send it to PD, and get it done right?
Thu Sep 03, 2009 7:33 am
If the guy has enough mechanical skills to swing a hammer and hit a drift.The sob will come out.Then if he wants to add one on the other side all he has to do is drill a hole with a 1/2'' drill and install another one.But you want the guy to tear the whole fuking thing apart like you would and send it to PD.When it is an easy fix.
If you use a SOLID piece of bar to hammer on and a heavy hammer it will turn loose.
Spray some penetrating oil on the top and let It soak.Tilt the motor where you can get a good swing on it and swing like a man NOT A GIRL.
Thu Sep 03, 2009 7:44 am
fair enough... point taken. just trying to give the guy some options.
Thu Sep 03, 2009 8:23 am
not to mention ur plans takes days... ours takes minutes. lol
Thu Sep 03, 2009 9:03 am
Kewl ur jets! It's done.
Thu Sep 03, 2009 10:59 am
I gots to know..... who's method did you use??????? :mrgreen:
Thu Sep 03, 2009 12:11 pm
Pro Drive m'fers
Thu Sep 03, 2009 12:29 pm
hey... they didn't get to the pinnacle of their careers by being stupid! :lol:
Thu Sep 03, 2009 12:58 pm
Thu Sep 03, 2009 1:13 pm
Thu Sep 03, 2009 1:26 pm
I called Brooks and said what in the HELL are you talking about?!! :lol: :lol:
Thu Sep 03, 2009 1:30 pm
Pro Drive m'fers
Thu Sep 03, 2009 1:39 pm
I know atleast one guy on MMT that can't keep a damned secret.... :roll: :lol:
Thu Sep 03, 2009 1:58 pm
Pro Drive m'fers
Thu Sep 03, 2009 2:23 pm
Fri Sep 04, 2009 7:39 am
so... what you're saying is that Crews' method was indeed correct, and that Stumpgrinder and Coastal can suck it? :mrgreen:
Fri Sep 04, 2009 2:36 pm
Yes ...Pro-Drive is sitting there saying...A nother Fuking Dumbass...Oh well we will take there money.He must be related to POO POO.. :lol:
Fri Sep 04, 2009 3:05 pm
Fri Sep 04, 2009 9:07 pm
got anything smartass to say coastal? :lol: :lol:
Tue Sep 08, 2009 11:34 am
Tue Sep 08, 2009 11:41 am
there ya' go... I knew you had something good to say :lol: :lol: :lol:
Tue Sep 08, 2009 1:02 pm
:D Biss
Tue Sep 08, 2009 1:28 pm
