It is currently Mon Dec 22, 2025 12:49 am
Reply to topic  [ 4 posts ]
 Lower unit Grease GTR35
Post Lower unit Grease GTR35
Hey yall was wondering do yall pump grease into the shaft after every run or just purge the lower unit out every 15 hours. Thanks
Wed Sep 16, 2009 7:34 am
Post Re: Lower unit Grease GTR35
I purge it after 15-20 hours.I've never just pumped grease into it,if I pull the plug to pump some grease I just push it all out until I start getting good grease coming out of the hole.
Wed Sep 16, 2009 7:45 am
Exactly, just purge it every 15 hours and only use da grease dat GT says use.
Thu Sep 17, 2009 7:57 am
I used Therma-Plex Aqua Bearing Greese as per the GT owners manual when I had mine - you might check with GT on what they want you to use now, I think they had started recommending another type of greese. You can get the thermaplex at Grainger Supply.
18x48 Brother Breaux Bateau w/ 36 PD
Thu Sep 17, 2009 4:42 pm
