It is currently Thu Jul 10, 2025 12:37 pm
Reply to topic  [ 38 posts ]
 PD reverse ram acting up again
Post PD reverse ram acting up again
I just had these seals replaced less that 2 months ago and now its acting up again. It will spin from reverse back to forward fast as shit without a problem. But going from forward to reverse, sometimes it will go, sometimes I have to nudge it a little to get it going. I have greased every f'n zert I can find. Removed the plug, greased in the tower, greased the reverse ram (where the bolt goes through), the actuation gear that the bolt goes through. Starting to piss me me off. Could these seals be f'd again, or am I missing something? It almost seems to be in a bine trying to go to reverse. But once in reverse, that sucker will go back to forward without a hitch.
Mon Nov 11, 2013 9:55 am
Post Re: PD reverse ram acting up again
What does your washer stack look like where the ram connects?
I had this problem, once. I'll see if I can locate the thread on how I fixed it.
Mon Nov 11, 2013 10:24 am
See if this will get you there:
viewtopic.php?f=41&t=30928
Mon Nov 11, 2013 10:28 am
Mon Nov 11, 2013 10:29 am
Oh yeah...also check your tension knob on the tower. It may be too loose.
Mon Nov 11, 2013 10:32 am
Mine started the day before the season opened. I went get a seal kit and took apart to re-seal it and found the piston that is screwed onto the shaft was loose. Tightened it, and working fine now.
Mon Nov 11, 2013 12:06 pm
If it goes good after you bump it, chances are it's the "alignment", you might have the reverse gear off one tooth or like said above, the washers one or two off, it doesn't take much to bind it. Bump it in forward and then reverse and see where the play is, it'll have some but the more your eliminate, the better it will work. I'll never have another hydro reverse just because of that, you can get the sob working perfectly. Pull the motor and put everything right back how you had it and the bitch wont work. The tall long bolts that hold the two main plates together with the bushings have some play in them also. You may want to loosen them and twist the whole thing one way or the other and then tighten it back down. It's a temperamental bitch but when you get it right, it'll stay.
The tension knob does nothing on the hydro...
Mon Nov 11, 2013 12:09 pm
I didn't think the knob did. It could be alignment, because if if remove the bolt at cycle it with nothing, the ram moves back and forth without a problem. Now, its under no load so I can't really tell if the seal is leaking by, but at least it moves back and forth.
I also didn't think about the teeth alignment. Anyone has a picture of the forward position so I can see the tooth alignment.
Mon Nov 11, 2013 12:28 pm
A picture will just piss you off because what works on theirs might not work on yours. LOL
Mon Nov 11, 2013 1:39 pm
Mon Nov 11, 2013 5:27 pm
Tue Nov 12, 2013 6:04 am
Thats what I said. :lol:
Tue Nov 12, 2013 6:25 am
:lol: Is that what you were trying to say??
Tue Nov 12, 2013 12:40 pm
Yes but I think I was getting mad thinking about and got side tracked, went home and kicked mine just for the reminder :lol:
Tue Nov 12, 2013 12:43 pm
:lol: :lol: did it finish the 1/2 revolution after? lol
Tue Nov 12, 2013 12:46 pm
it works flawlessly now and I don't plan on pulling that motor anymore, it's had all the upgrades I'm gonna do to it.
Tue Nov 12, 2013 12:59 pm
Tue Nov 12, 2013 1:00 pm
Tue Nov 12, 2013 1:08 pm
Mon Nov 18, 2013 1:10 pm
Y'all leave bayouboy alone, he,s busy down here.....lol
Gator tail
Mon Nov 18, 2013 1:47 pm
Mon Nov 18, 2013 4:29 pm
Tue Nov 19, 2013 11:36 am
picture?
Tue Nov 19, 2013 11:40 am
Gator tail
Tue Nov 19, 2013 3:28 pm
Tue Nov 19, 2013 3:44 pm
Gator tail
Tue Nov 19, 2013 3:58 pm
Good Lawd!!! :lol:
Tue Nov 19, 2013 8:52 pm
Wed Nov 20, 2013 10:12 am
Found the problem, at least I think. I greased everything, every f'n grease fitting I could find. but I noticed something. Where the gears mesh, was dry and had mud on them.
So I greased the shit out of it. Now the first time I did it, most of the grease got pushed out. So I caked more in. The more I cycled it, the more slicker it became. Not sure if I'm suppose to grease that, but it worked like a champ. Even greased where the ram rides on the washer placement.
Tue Dec 03, 2013 6:18 am
I went back and read, but didn't see it anywhere other than "every grease zerk you could find." And this may be one of those... But did you find the grease zerk beneath the gear? Only reason I ask is because I have grease coming out all up underneath that gear plate....didn't notice it in your pictures.
Tue Dec 03, 2013 8:24 am
Tue Dec 03, 2013 9:52 am
I'm thinking about grease ports 1 & 2
Tue Dec 03, 2013 12:14 pm
Shit, I did the bottom bit the ram and cover must have blocked that top one. I'll hit that sucker too.
Tue Dec 03, 2013 12:42 pm
That top ones a bitch with the ram. Might want to think about extending it out...
Tue Dec 03, 2013 1:19 pm
I probably go through more grease and WD-40 than the average person. Could be why I have grease piled up around my reverse stuff....and leave a sheen in the water when I launch! :lol:
Tue Dec 03, 2013 4:11 pm
Tue Dec 03, 2013 6:58 pm
Heck NO!! Just a good student learning from reading what the Masters like you have written!
Tue Dec 03, 2013 8:56 pm
Users browsing this forum: No registered users and 51 guests
