| New prop... Installing question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=4807 |
| Author: | WestEndAngler [ Wed Sep 23, 2009 8:21 am ] |
| Post subject: | New prop... Installing question |
How tight or is their a specification of how many FT/LBS I should tighten the nut that holds the prop on? Once there's no play in the prop etc. |
| Author: | richardb [ Wed Sep 23, 2009 8:39 am ] |
| Post subject: | Re: New prop... Installing question |
The prop is thread on and every time you hit something it gets tighter so I put the prop on and tighten the nut snug and run for a while and the check the nut on the back and see if it needs to be tightening again. I do not know if there is a spec for how many ft/lbs. |
| Author: | muddiejeep [ Wed Sep 23, 2009 8:46 am ] |
GT uses a hex shape for their props they are not threaded on. I don't know maybe you can call GT or wait for a response on here |
| Author: | dog walker [ Wed Sep 23, 2009 9:30 am ] |
I just put it on and snug it down and I have never had an issue,its got a lock nut on it so there is no need to torque the piss out of it. |
| Author: | WestEndAngler [ Wed Sep 23, 2009 11:25 am ] |
I know they aren't threaded my question was about the nut. I think I got it answered... I'll call Hoyt if I have any questions but was making sure if I snug it up I'll be good... |
| Author: | Da-Cajun-Angla [ Wed Sep 23, 2009 12:54 pm ] |
i just tighten mine till i go...uuugh! |
| Author: | MaXXis85 [ Fri Sep 25, 2009 7:00 am ] |
German torque spec Good-n-tight. |
| Author: | craig [ Fri Sep 25, 2009 7:20 am ] |
Tighten it up and hit the wrench a couple times with a hammer and your good to go. |
| Author: | DMC [ Fri Sep 25, 2009 8:59 am ] |
60ft.lbs. according to the GT owners manual on the GT website. |
| Author: | coondik [ Fri Sep 25, 2009 9:03 am ] |
| Author: | MaXXis85 [ Fri Sep 25, 2009 9:28 am ] |
Hamma and duct tape to keep the prop from tuning will get ya in da right TQ specs! |
| Author: | bayouboy [ Fri Sep 25, 2009 9:56 am ] |
and once you have the nut good an snugg you might want to hammer the end of the shaft too! you know kinda mushroom it over a bit just to be safe |
| Author: | dog walker [ Fri Sep 25, 2009 11:53 am ] |
| Author: | WestEndAngler [ Fri Sep 25, 2009 1:54 pm ] |
| Author: | LA OUTLAW [ Fri Sep 25, 2009 6:50 pm ] |
| Author: | bayouboy [ Fri Sep 25, 2009 6:59 pm ] |
