It is currently Thu Jul 10, 2025 12:39 pm
Reply to topic  [ 12 posts ]
 Short tails vs Longtails
Post Short tails vs Longtails
Im a newbie to mud motors and was wondering what are pros and cons of long tails and short tails?
Im interested In a mud motor for duck hunting.
Tue Dec 10, 2013 6:31 pm
Post Re: Short tails vs Longtails
Longtails are good for skinny water and mud.
SD are better for deeper water and long distance as they are easier to handle.
Sent from my iPhone using
Tue Dec 10, 2013 6:38 pm
the godevil website has a pretty good explanation btwn the two, but i'll sum up my experiences with both.
LT:
great with the harder bottoms
if it gets you in, it should get you out (due to slower speed, doesnt get you in as bad of a bind, and you can find pockets with the prop to get you going due to the reach)
slower
less and easier maintenance (less moving parts, less to break, simpler design)
SD:
faster
better for soft bottoms where the prop speed makes a difference
can get you alot more places, just gotta make sure you'll have enough room to get it back out
tends to carry a load better, but when it's at it's limit, performance drops off quick
I look at it like this: if you run marsh type areas or alot of open water, go with the SD. If you run areas with shallow harder bottoms, get the LT. It may not always be that simple, but it's a good basis for helping guide you.
Tue Dec 10, 2013 6:48 pm
Tue Dec 10, 2013 6:54 pm
http://www.godevil.com/Comparison.html Again, take it with a grain of salt, but this page gives a fairly good explanation. There are some caveats, and getting the right motor with the right boat is THE MOST important thing if you run in shallow stuff.
Tue Dec 10, 2013 7:04 pm
And when all else fails, use the damn search feature.
Tue Dec 10, 2013 7:17 pm
It all depends on the area you run.
Tue Dec 10, 2013 7:30 pm
Listen to ^that^ guy. He's pro staff...
Tue Dec 10, 2013 7:33 pm
Tue Dec 10, 2013 7:46 pm
23 swomp/ 1542 tracker
Tue Dec 10, 2013 8:22 pm
Long tails are much more work but they will shine in rough and tuff areas especially in the stumpy swamps. Longtails are slower and don't do so well in hyacinths because you have more hanging in the water. They are tough and simple.
Surface drives are faster, easier to drive, and can skim across some muddy areas. They do well in vegetation and do well in hyacinths to a point. I think Longtails dig out of mud a little better but the SD clan may disagree with that.
Tue Dec 10, 2013 8:47 pm
Perfect !! Thanks for all the info
Tue Dec 10, 2013 10:21 pm
Users browsing this forum: No registered users and 53 guests
