It is currently Thu Jul 10, 2025 12:37 pm
Reply to topic  [ 15 posts ]
 Squeaking problem
Post Squeaking problem
I have an 08 35gtr. When i put it in gear in the water its making a squeaking noise loud and gets worse the more throttle i give. When it is out of the water on the trailer and i put it in gear it makes no noise whatsoever. So my question is what is causing this? Any ideas or if anyone has a clue it would help tremendously. Im scared to run it anymore.
Fri Jan 03, 2014 2:42 pm
Post Re: Squeaking problem
Check brake pads. Could be pad rubbing on rotar.
Fri Jan 03, 2014 2:49 pm
Hmm ok i will check that. You dont think it would squeak out of the water too though?
Fri Jan 03, 2014 2:53 pm
The added vibration created by the prop being in water could cause it. IDK take the clutch cover off and check it.
Fri Jan 03, 2014 2:56 pm
Will try that. Should i take the caliper off and run it in the water to know if thats the problem?
Fri Jan 03, 2014 3:04 pm
No just look at it and see if its touching
Fri Jan 03, 2014 3:05 pm
Its not suppose to be touching at all? Cause if its like any other brake system ive messed with the pads are still pretty much touching even when u let off the brake.
Fri Jan 03, 2014 3:11 pm
Check your intake gaskets for leaks...
Fri Jan 03, 2014 3:15 pm
What intake gaskets...where at
Fri Jan 03, 2014 3:21 pm
You're gonna have to take the cowling off to get to them. Can you take the spark plugs out and see what they look like, if you have a black one and then one that's creamy color, that side is leaking indicating a lean mixture with the intake sucking in air. Sometimes the intake will leak and the gasket will act like a reed as whistle, getting worse the morse gas you give it while the boat is under a load. I'm not saying that's your issue but it's something to check.
Fri Jan 03, 2014 3:35 pm
Ok thanks. I will check plugs. But it doesnt sound like an air whistle its more metallic like a bearing or something. Im not familiar with where any bearings are or any of the drive components really.
Fri Jan 03, 2014 3:55 pm
Maybe some others will chime in, I had one throw me for a loop, sounded just like a squeaking belt and got louder, thought the fan was rubbing the shroud and turned out to be an intake leak where the intake meets the head.
Good luck
Fri Jan 03, 2014 4:05 pm
Thanks
Fri Jan 03, 2014 4:15 pm
Anybody have any other ideas??
Sun Jan 05, 2014 8:44 am
belt rubbing on the back of the frame! check that also
GatorTail 18x54 extreme Center Console 37EFI "Ole Man Rig"
Sat Jan 11, 2014 7:40 pm
Users browsing this forum: No registered users and 51 guests
