redfish2
gator-tail 3 blade prop ????
I have hoyt stage one with center console , with a BIG load how would a 3 blade prop do for me ?
The 2 blade prop does awesome when it is new , but as much weight as I carry it dont last long at all. Trying to get something to last me longer .
Thanks for any info !
Thu Mar 20, 2014 7:31 pm |
msm8281
Re: gator-tail 3 blade prop ????
My experience on an 18x48 is that the 2 blade carries a load better than a 2 blade by far on a stage 2 motor. However with the 3 blade I was able to cruise pretty good at a lower rpm when lightly loaded.
Thu Mar 20, 2014 7:54 pm |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
Thu Mar 20, 2014 8:08 pm |
msm8281
Thu Mar 20, 2014 8:09 pm |
Bigrich
Wasn't sure if u knew what prop you was even trying
Thu Mar 20, 2014 8:13 pm |
msm8281
Same load with 12"2 blade 4400 rpm and 25mph
Thu Mar 20, 2014 8:17 pm |
Bigrich
It's really funny how the 3 blades seem to work for ppl differently. Some have lost speeds and some have gained. Guess just depends on ur boat and motor. 3 blade helped me
Thu Mar 20, 2014 8:30 pm |
msm8281
Load was (36) 2x4x12 treated. 2 batteries. 18 gal gas, me, dog,and 48 qt ice chest, and about 100lbs of tools. So it was a pretty good load.
Thu Mar 20, 2014 8:35 pm |
Bigrich
True I'm sure Jamie prolly cried when he saw his boat was now a work boat
Thu Mar 20, 2014 8:37 pm |
msm8281
He did shed a tear when we swapped trailers and I put a scratch on the bottom:lol:
Thu Mar 20, 2014 8:39 pm |
msm8281
Back to the prop...I did like it for light load crusing.
Thu Mar 20, 2014 8:40 pm |
Bigrich
3 ppl ice chest and all hunting gear I gained 3 mph over a 2 blade
Thu Mar 20, 2014 8:43 pm |
msm8281
Weird for sure
Thu Mar 20, 2014 8:45 pm |
Bigrich
That's y I'm saying everyone is seeing different things with these props. But I will tell ya if you have a 45 tooth pulley you better keep the 2 blade
Thu Mar 20, 2014 8:47 pm |
msm8281
I do have a 45. Thats probably it.
Thu Mar 20, 2014 8:49 pm |
Bigrich
Yes geared to high
Thu Mar 20, 2014 8:55 pm |
lunacris
Joined: Thu Mar 29, 2012 8:31 pm Posts: 3251 Location: Da Parish
probably the combo of things here: outdrive length, HP, pulley, and boat.
what I've gather from everyones opinion is that this is not just a prop that you buy and go. some things need to be considered or tuned to run it.
_________________ GatorHide - MB
Thu Mar 20, 2014 9:15 pm |
ak
Joined: Tue Oct 23, 2012 11:09 am Posts: 897 Location: MATAGETDOWN, TX
Need to demo one of these props before I'm sold I don't run alot of vegetation just alot of sand so shorter blades and maintaining a plane at lower rpms with less vibs got me interested
Fri Mar 21, 2014 4:39 am |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
I saw an increase in speed with a load when. I swapped to the 3 blade. Empty didn't really notice anything besides able to cruise at lower rpm and less vibration.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Fri Mar 21, 2014 6:36 am |
Bigrich
Fri Mar 21, 2014 7:48 am |
redfish2
Thanks for the info , this is my boat , with 4 ppl with a brand new 2 blade prop I run 22-23 mph but the prop don't last about 12-15 bowfishing trips . I was just trying to see if the 3 blade would last longer ?
Mon Mar 24, 2014 5:27 pm |
msm8281
If u don't have mods and want to run with a load, you should stick with a two blade.
Mon Mar 24, 2014 5:32 pm |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
Mon Mar 24, 2014 6:26 pm |
msm8281
Man I got a 45 with a stage 2 and im not quite sure yet. I have not run it much yet to know for sure. What I can tell u is that I had it loaded to the gills with lumber and tried both props with same load and the two outperformed the three by far.
I think the 48t will make a big difference.
Its a beast in the mud though.
Mon Mar 24, 2014 6:35 pm |
dadazzsaleen
Joined: Tue Nov 09, 2010 11:24 pm Posts: 743 Location: Mandeville, LA
^^^ what rpms do you normally turn?
_________________ [Stage 2.5]
Mon Mar 24, 2014 6:40 pm |
msm8281
New boat to me and new mods. I haven't run it much yet.
3 blade just me 4300-4400 Worn 2 blade 4600 ish
Mon Mar 24, 2014 6:51 pm |
msm8281
Something else I noticed is that it cruises good at a lower rpm with 2 people.
Mon Mar 24, 2014 6:52 pm |
redfish2
I have stage 1 from hoyt
Mon Mar 24, 2014 7:20 pm |
msm8281
Mon Mar 24, 2014 7:22 pm |
deltaduckmaster
Going from a 45 to a 48 is like adding another mod to your motor.
Mon Mar 24, 2014 7:37 pm |
redfish2
Im not sure , It is a 2009 motor , I guess it is 45
Mon Mar 24, 2014 7:44 pm |
hydrilla gorilla
put a 3 blade on yesterday. Love it. My boat is a 2054 with 3/16 bottom CC stage 2 motor. The boat itself is a load and I ran it with just me in the boat. I noticed it may have got on plane a little faster not much. The reverse is 100% better. I gained about 1-2 mph but it was a little choppy so it was hard to tell. i normally ran about 4250 RPMs in its sweet spot and i was only running 3900 RPMs with the 3 blade. The motor sounded like it was running much easier and purred like a kitten. i do have a square chine boat so in a sharp turn i go into a instant 360 if i am not careful lol. with the 3 blade it seemed as if it held on a little longer before it wanted to spend out of control also. So the question everyone want to know is it worth it. In my case YES.
Tue Mar 25, 2014 7:53 am |
OwenDickeson
I don't think lugging down a stage 2 motor to 3900 rpms with a light load is a good idea IMO.
Sent from my XT1080 using Tapatalk
Tue Mar 25, 2014 9:41 am |
cb5331
Tue Mar 25, 2014 10:33 am |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
Tue Mar 25, 2014 11:25 am |
AKA Freshwaterkilla
I agree everyone I have seen tore up has usually been in a bind or loaded up bad
Tue Mar 25, 2014 11:36 am |
hydrilla gorilla
so you all are saying even though i dont have to run the 4300 rpms i need to trim up and run them or trim down and run them? i am just thinking running less rpm's getting the same or better speed would be better for my motor. According to the comments above you all are saying it is worse on the motor. I am really confused now.
Tue Mar 25, 2014 2:42 pm |
hydrilla gorilla
i also think my comment may have been worded bad. When i was running 3900 rpm's i am not at full throttle.
Tue Mar 25, 2014 2:54 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
Their just saying don't lug it down. Same with tractors, mowers, weed eaters, etc. The engine has to work harder if you don't let it run.
Tue Mar 25, 2014 6:02 pm |
richard1220
Computer Software
Thanks for all the tips mentioned in this article! it’s always good to read things you have heard before and are implementing, but from a different perspective, always pick up some extra bits of information.
_________________ |
Wed Jun 05, 2019 12:07 pm |
