It is currently Wed Apr 24, 2024 4:45 pm
Reply to topic  [ 25 posts ]
 Replacing GT seal
Post Replacing GT seal
I've just started to notice a very small amout of grease on my belt. I ordered the new seal from Gatortail. How difficult are these to replace??
Fri May 16, 2014 2:15 pm
Post Re: Replacing GT seal
Nothing to it. You need snap ring pliers to make the job easy.
Also a heavy rubber mallet and good penetrating oil if you ran in saltwater. This is for the pulley and taper lock if it is corroded bad like mine was.
Sat May 17, 2014 3:24 am
Here is a pic. Just use rubber mallet?
Sat May 17, 2014 4:28 pm
Remove the 2 allen head screws from the taper lock and place one back in the middle hole. The pulley should slide down towards the prop off of the taper lock with the tension of the screw pushing them apart. If that does not work, then soak in good penetrating fluid and hit the pulley with the rubber mallet and see if it frees itself while tightening up on the allen bolt you screwed back in the middle hole. Gradually hit harder since the pulley can be bent.
Sat May 17, 2014 4:38 pm
Sat May 17, 2014 4:42 pm
There are 2 snap rings in front and behind the bearing which hold it in place. The seal goes on top of that.
Sat May 17, 2014 4:49 pm
Thanks
Sat May 17, 2014 5:26 pm
You good?
Just paying it forward..... I rebuilt my lower 2 weeks ago with some help from others on here.
Sat May 17, 2014 6:05 pm
Are you hitting the pulley toward the prop?
Sat May 17, 2014 6:12 pm
Thanks again BSH!!
Mon May 19, 2014 6:10 am
Wed May 21, 2014 1:31 pm
Huh?
Wed May 21, 2014 4:52 pm
Fri May 23, 2014 6:21 am
I'm at a standstill trying to get this pulley and taper lock off the shaft. I've tried everything posted above but I can't get it figured out. If anyone has any suggestions or help, that'd be awesome.
Sun Dec 14, 2014 3:02 pm
I soaked mine in pb blaster overnight and used a rubber mallet. Beat it down
Mon Dec 15, 2014 10:00 am
Whack that fucker. We just tok one off an 04 that ran its whole life in salt. Took a socket extension and steel hammer and hit the gear part towards the belt and tapped a screw driver in where it compresses and tapped it off. If that doesn't work just get a gear grab and put the nut on the threaded part and impact it.
17x54 custom CC with stage 3 GTR.
Mon Dec 15, 2014 4:26 pm
Kool-Aid Brigade
www.southernfowler.com
Tue Dec 16, 2014 9:19 am
The cup is stainless and yes it's reverse threads
Tue Dec 16, 2014 9:27 am
Kool-Aid Brigade
Tue Dec 16, 2014 9:36 am
getting out doesnt matter if u mess it up once you replacing so a pick or a flathead screwdriver will get it out
Tue Dec 16, 2014 9:59 am
Ben - I meant the SS sleeve not the seal.
Kool-Aid Brigade
Tue Dec 16, 2014 10:11 am
just pushes out. rides on the lip of the seals it meant to be a wear part so you dont damage shaft. or are you talking about the housing itself? if so pipe wrench works
Tue Dec 16, 2014 10:16 am
Kool-Aid Brigade
Tue Dec 16, 2014 10:42 am
How are y'all getting the bearing out?
Tue Jun 27, 2017 8:03 am
Tue Jun 27, 2017 8:12 am
Users browsing this forum: No registered users and 138 guests
