It is currently Mon Sep 22, 2025 12:50 am
Reply to topic  [ 35 posts ]
 2009 Prodrive Clutch singing while in neutral.........?
Post 2009 Prodrive Clutch singing while in neutral.........?
hello can anyone tell me there experience with the prodrive clutch making a scratching whining noise while in neutral....... i put it in gear and the noise goes away. it sure feels like the clutch brake is dragging while not engaged.?.?.? i was gonna order one tomorrow but would like to hear what y'all think before i do. thanks a bunch !!!! God Bless
Mon Jun 12, 2017 9:06 pm
Post Re: 2009 Prodrive Clutch singing while in neutral.........?
Sounds like your onto it. Is the prop still spinning a little while in neautral
Mon Jun 12, 2017 9:26 pm
Mon Jun 12, 2017 9:50 pm
Then the magnetic brakes are working. Maybe a bearing in the clutch starting to get mad. Hard for me to say replace now or not , but dont wait til duck season to check it out
Mon Jun 12, 2017 10:08 pm
Mon Jun 12, 2017 10:18 pm
The singing you hear is the bearing starting to go out. The bearing defect is ok as long as it doesn't generate too much heat. Too much heat will lead to its failure and damage the windings of the clutch. Then its gone. Your good for now, but I would order the new one before it leaves you stranded.
Tue Jun 13, 2017 5:29 am
Tue Jun 13, 2017 6:54 am
When its gone, it will look similar to this. Notice how the windings are exposed. Too much heat will cause the coating to melt over the windings and thus allow the windings to "touch off" or go straight to ground. Then its done.
Wed Jun 14, 2017 4:19 am
Or, like this...
And, don't forget that the bushing goes back on with tapered end toward the engine.
Wed Jun 14, 2017 6:49 am
With a singing sound, you are close to getting stranded in the middle of nowhere.
Wed Jun 14, 2017 8:10 am
Wed Jun 14, 2017 8:12 am
Easy swap...other than having to pull the engine from the tower. Oh yeah...this is what they look like when the bearings are bad...
Wed Jun 14, 2017 8:38 am
Changing a clutch on a PD can be easy or a nightmare..its a 50/50 lol
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Jun 14, 2017 10:45 am
Tips...
Use some fine grit emery cloth to polish the crankshaft before removing the old one and installing the new one.
PB Blaster to help remove the old one; any lubricant to help install the new one.
Don't bang on the new one with a hammer. I used a piece of 2 x 4 and still used a rubber mallet to lightly tap the new one over the crank.
I torqued the clutch bolt to 48 ft-lbs per the aftermarket manufacturer recommendations.
Wed Jun 14, 2017 10:56 am
Xtreme Outdoor Power asked for my crankshaft dimensions (length out of the tub). They sent me a clutch with a washer/spacer to place between the clutch and the PD bushing.
Wed Jun 14, 2017 11:04 am
I use the impact and red Loctite. I see a lot more come loose than not...
Bayou Surface Drive
337-351-0362
Wed Jun 14, 2017 12:42 pm
Thu Jun 15, 2017 4:20 am
Thu Jun 15, 2017 4:23 am
Thu Jun 15, 2017 4:25 am
Bayou Surface Drive
337-351-0362
Thu Jun 15, 2017 7:53 am
Thu Jun 15, 2017 8:57 am
Fri Jun 16, 2017 11:57 am
Just use an impact
Fri Jun 16, 2017 4:41 pm
Pull the flywheel guard...drop a socket or big crescent wrench on the flywheel nut. Easier with two people...but, I did it solo.
Fri Jun 16, 2017 4:51 pm
okay doke ! thank you both !!!
Sat Jun 17, 2017 3:52 am
can i ask you gents how to tighten the clutch bolt back when putting the new one on ? i'm trying to torque it but i keep spinning the motor over........
Sat Jun 24, 2017 3:52 pm
Impact
Sat Jun 24, 2017 4:43 pm
Sat Jun 24, 2017 5:30 pm
Sat Jun 24, 2017 8:13 pm
Sat Jun 24, 2017 9:06 pm
The wire mesh guard and screen above the flywheel....pull them off, exposing the nut which holds the flywheel in place. Use it as a backup while tightening the clutch bolt.
Sun Jun 25, 2017 3:54 pm
48-50 foot pounds is too little torque IMO for a 7/16" diameter fine thread bolt. I see a lot of PD clutch bolts back out and cause the clutch to wobble on the shaft. I use an impact and red Loctite. I'm Marcus with BSD and I approve this message LOL.
Bayou Surface Drive
337-351-0362
Mon Jun 26, 2017 5:47 am
Mon Jun 26, 2017 9:27 am
Mon Jun 26, 2017 9:28 am
