It is currently Thu Jul 10, 2025 4:04 pm
[ 8 posts ] |
ha2
 PD lower knuckle
Is there a vent on the lower knuckle gearbox? I change oil this spring and checked it after fishing today and when i pulled the plug gearbox had pressure in it and i lost quite a bit of oil and I know i didn't over fill it when i change it.
_________________ 1856 Phowler commercial hull with extra flotation so I can run shallower. Pushed by a stock Prodrive until my wife gives me more money
Fri May 23, 2014 5:38 pm |
ha2
 Re: PD lower knuckle
no one knows if theres a vent for the gearbox that goes up through the tower? I been dearching old threads for the past 3 hrs looking for this answer. Thought i've seen pics before where people have had gear oil come out up by the clutch.
Fri May 23, 2014 8:37 pm |
OwenDickeson
Yes some of them were vented.
Sat May 24, 2014 11:18 am |
ha2
You know what years they were vented? Mines a 12. And also where the vent is located so I could see it mines maybe plugged.
Sat May 24, 2014 4:21 pm |
banded-mallard
Tue May 27, 2014 7:55 am |
Will
It's best not to have a vent and chances are yours does not, they went to no vent. I'd say it would be fine to have a little positive pressure, will help keep water out. Was it cold when you changed it and then hot now? Thermal expansion? You will be fine as long as there's no water in the oil.
Tue May 27, 2014 8:22 am |
ha2
Yes it was cold I did it late this winter and I'm from iowa so that probably explains it. I noticed knuckle seemed hot too before I drained some of the oil out probally hot because I ran it to full?
Tue May 27, 2014 2:55 pm |
Will
Nahh, its like the differential on your truck, gonna build some heat.
Tue May 27, 2014 3:33 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 42 guests |
