It is currently Sat Sep 20, 2025 11:42 pm
Reply to topic  [ 3 posts ]
 question bout a longtail prop
Post question bout a longtail prop
i have a 20 hp beavertail, i think that a 9x4 or a 9x5 comes on it stock....do yall think that a 9x7 would be too big for it?? ive heard of some guys putting a little bigger prop on their motor, but is this prop too big? any advice will help.
1542 Landau w/ 20 hp BT Longtail
custom dual exaust
"Hatchie Bottom" paint job
Fri Oct 16, 2009 5:12 am
Post Re: question bout a longtail prop
My 23 GDLT came with a 9x6 and on a 16x48 (500lbs) and it
was the best all around pitch --- I tried the 9x7 and solo
it was faster by 2 mph but with 2 man hunting loads
it was about 2 mph slower than the 9x6 and weak "in the hole"....
Every hull is different --- but with the LT each pitch
change is pretty drastic --- the 9x5 might even be
a better choice if your hull or loads are on the heavy side...
If your usage is hard on the prop - ie - lots of sand and oysters
then if you start a bit "overpitched" it will wear into a sweet spot...
Fri Oct 16, 2009 8:32 am
thanks for the advice, i think i might go with a 9x5 or a 9x6...which ever is just one step up from stock...i can't remember. i think that the 9x7 might just be a lil too big. most of my loads are 2-3 guys and all the random hunting necessities....
custom dual exaust
Fri Oct 16, 2009 1:44 pm
