question bout a longtail prop http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=5378 |
Author: | hatchie rat [ Fri Oct 16, 2009 5:12 am ] |
Post subject: | question bout a longtail prop |
i have a 20 hp beavertail, i think that a 9x4 or a 9x5 comes on it stock....do yall think that a 9x7 would be too big for it?? ive heard of some guys putting a little bigger prop on their motor, but is this prop too big? any advice will help. |
Author: | Gigafowl [ Fri Oct 16, 2009 8:32 am ] |
Post subject: | Re: question bout a longtail prop |
My 23 GDLT came with a 9x6 and on a 16x48 (500lbs) and it was the best all around pitch --- I tried the 9x7 and solo it was faster by 2 mph but with 2 man hunting loads it was about 2 mph slower than the 9x6 and weak "in the hole".... Every hull is different --- but with the LT each pitch change is pretty drastic --- the 9x5 might even be a better choice if your hull or loads are on the heavy side... If your usage is hard on the prop - ie - lots of sand and oysters then if you start a bit "overpitched" it will wear into a sweet spot... |
Author: | hatchie rat [ Fri Oct 16, 2009 1:44 pm ] |
thanks for the advice, i think i might go with a 9x5 or a 9x6...which ever is just one step up from stock...i can't remember. i think that the 9x7 might just be a lil too big. most of my loads are 2-3 guys and all the random hunting necessities.... |
