It is currently Thu Jul 10, 2025 2:41 pm
Reply to topic  [ 10 posts ]
 Mudbuddy 31hp surface drive prop nut removal?
Post Mudbuddy 31hp surface drive prop nut removal?
I'm trying to figure out how to take the nut and prop off my newly acquired 31hp short shaft and I was wondering if you guys know of the best way to do that.. I've done it on long shafts before but never a short shaft. Any advice would be helpful. Thanks!
The gee
Tue Jul 15, 2014 9:49 pm
Post Re: Mudbuddy 31hp surface drive prop nut removal?
Impact wrench
Wed Jul 16, 2014 7:01 am
hmm. Ok, but don't you need to keep the prop from spinning?
Wed Jul 16, 2014 8:23 am
You can use a big ass pipe wrench over the hub to keep it from spinning. This works, but it's a bit crude for my liking. I did it this way once.
Shortly after that fiasco, I built a spanner wrench of sorts that has two 1/2" dia. rods that lay in the radius intersection of the blades and the hub. I welded those rods into a 3' piece of 1/2 x 1 cold rolled bar for a handle. The issue is having to hold the shaft from spinning while you remove the or loosen the prop. The trick is imo, a sharp blow to the prop, not steady pressure. For the nut the spanner wrench and a 1/2" drive impact wrench.
I haven't found any prop nuts or props I could break loose with it! I made it originally for my Go Devil long tail years ago but it adapted fairly easy to the sd too.
I've actually taken a couple off for guys that I ended up having them jump on the spanner wrench in order to break the prop loose!
FYI: Use a copper based anti seize on the threads and thrust washers and don't use sparingly.............
Good luck
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Wed Jul 16, 2014 9:01 am
WTF computer! :lol: stuttering bee otch
1854 Prodigy Open
HDR/Stage 3 mods
Wed Jul 16, 2014 9:02 am
It's the tri-fecta post wtf?! ;)
1854 Prodigy Open
HDR/Stage 3 mods
Wed Jul 16, 2014 9:03 am
Wed Jul 16, 2014 2:15 pm
I do pm me your cell number ill text it to ya.
1854 Prodigy Open
HDR/Stage 3 mods
Wed Jul 16, 2014 6:03 pm
17x54 Extreme W/ GTR-35L Stage 1
Wed Jul 16, 2014 6:09 pm
I got her off. Thanks for all your help guys! I used a pipe wrench on the old prop and put the socket on the nut with a cheater bar and she finally broke lose. Talk about a MILLION times easier than those threaded shafts on my old long tail. Whoever came up with the idea of that hex shaft deserves a pat on the back! Thanks for the help guys, I really appreciate it.
The Gee
Thu Jul 17, 2014 8:39 am
Users browsing this forum: No registered users and 48 guests
