It is currently Thu Jul 10, 2025 2:46 pm
[ 6 posts ] |
EastTexasDucks
 PD gear oil?
i just recenty upgraded to a pro drive and was wondering if you can over fill the gear oil reservoir? i drained it and filled it up until it was over flowing then squirted a little more and capped it really fast. so that none would run out, will it be ok?
_________________ WingPhenes™ 18x54 ProDrive Powered James Gang Bang
Fri Jul 25, 2014 6:36 pm |
Quackhead62
Joined: Fri Nov 30, 2012 7:47 pm Posts: 931 Location: Maurice,La
 Re: PD gear oil?
Yea you will be good. When u fill from the back hole and u see it come out the front put ur plugs back in and you will be good to go.
_________________ Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust Pushing a 17X54 Pro-Drive X-Series boat
Fri Jul 25, 2014 7:56 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: PD gear oil?
^ Correct, All depends on the year of the L/U. The old style (07-10 oil bath prop shaft) will require a little more oil and if you filled it from the top you may want to recheck it. It takes a while to drain down. New style 11-14 greased shafts and oil bath gears not an issue when filling.
Fri Jul 25, 2014 8:25 pm |
EastTexasDucks
 Re: PD gear oil?
Ok this is a 2012. So should I refill it from the bottom or let her roll
Fri Jul 25, 2014 9:27 pm |
bayouboy
 Re: PD gear oil?
2012 your good to go my boy!!
Wait! I said that a little premature my boy. Did you also grease the shafts?
Fri Jul 25, 2014 9:32 pm |
EastTexasDucks
 Re: PD gear oil?
Yes sir, all greased up. Thanks for the help!
Sat Jul 26, 2014 10:13 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 31 guests |
