It is currently Sun Sep 21, 2025 10:19 pm
Reply to topic  [ 30 posts ]
 why aftermarket?
Post why aftermarket?
u guys that are running aftermarket props, what r u gaining from running the aftermarket props u are, opposed to the different props that the factorys are offering.
Thu Oct 22, 2009 4:58 pm
Post Re: why aftermarket?
In my case it dropped the rpms some but it is a little faster than my stock prop.It has held up good in the mud as far as wear goes,but I'll see how it does during hunting season.
Thu Oct 22, 2009 5:15 pm
dog walker what prop are you running??
My Chessie is the Queen of the Marsh!!!!
"The democracy will cease to exist when you take away from those who were willing to work
and give to those who would not." Thomas Jefferson-1802
"When the Government fears the people that is liberty
When the people fear the government that is tyranny"- Thomas Jefferson
Thu Oct 22, 2009 5:34 pm
Thu Oct 22, 2009 5:36 pm
Stock.
Thu Oct 22, 2009 5:40 pm
with more power you can run a more aggresive prop to lower rpms and run faster, and have more hole shot.
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Thu Oct 22, 2009 5:52 pm
Thu Oct 22, 2009 6:06 pm
The big blade is the best all around prop for holeshot and reverse propulsion.
Thu Oct 22, 2009 6:17 pm
Thu Oct 22, 2009 6:18 pm
Its a hopkins 12x12,I got it to try it out.It is neck and neck with the GT big blade as far as performance but like I said it was a little faster and it lowered the rpms.You may as well run the stock prop,the gains were not that impressive but it has a lot of meat on it and so far it has held up well.I compared the props at the same time did the swap in the field but I do not have the exact rpms or speeds.The rpm drop was about 300 or so and maybe .5-1mph and that is it.
My better speeds with the GT prop will come with a prop with a some wear on it.This is on a GTR with Hoyts work done to it.The best speeds have been 34.8 on a 17x54GTB in about a foot of water and a slight breeze at the stern.It'll run 32-34 average skinny and deep
Thu Oct 22, 2009 7:37 pm
Hopkins props last longer in the sand.They are a harder material but every prop he sells you will be different.I have ran 3 of his props on 2 different motors and never had a problem.
Thu Oct 22, 2009 8:39 pm
What is this Stage 1 prop I have been hearing about? I believe Stump was working on it. Must be Super Top Secret since I know nothing about it.
Fri Oct 23, 2009 12:34 am
Fri Oct 23, 2009 6:21 am
Pro Drive m'fers
Fri Oct 23, 2009 9:24 am
I cant wait for ben to have the props ready, but will be worth the wait.
Fri Oct 23, 2009 10:01 am
Fri Oct 23, 2009 12:14 pm
It was designed to run on a PD so my guess is yes.
Pro Drive m'fers
Fri Oct 23, 2009 12:36 pm
What will the requirements be for this prop? Will you need a carb, exhaust & headwork, 2 out of three, or what? I'm just curious what else I will have to spend money on once I get tired of hearing how good these props are.
Sat Oct 24, 2009 1:22 am
Pro Drive m'fers
Sat Oct 24, 2009 3:55 pm
Mon Oct 26, 2009 5:29 pm
17x48 extreme stage 2 GTR
Mon Oct 26, 2009 5:46 pm
Well Terry that is the same thing that Kyle said but this prop is running better than the last GT big blade that I got.All around it beat what I had.It was not like strapping on a rocket booster it was just alittle faster.
Mon Oct 26, 2009 7:48 pm
Tue Oct 27, 2009 6:54 am
I tried the 12 x 12 hopkins and lost 2 mph and I had a hard time stepping a load. I wanted to try taking some pitch out but never did. I think the stock GT big blade is the best one. The thing about props is they are all slightly different. It's very hard to get 2 props that perform exactly the same.
Tue Oct 27, 2009 7:08 am
I only compared it against one new gt prop that I had all the other ones that I had were as sharp as knives.I've never tried the 11x11 with my boat and motor,the 9x11 does not do anything for it with the mods.I had a worn big blade that would out run anything that I put on it but it just got to the point of no return.
While frogging I had 2 other guys my size two batteries,ice chest with drinks,and 12 gallons of gas and the prop did just fine stepping that load in any conditions.With any load that I ran in it this summer the numbers were neck and neck but empty is where you would see the slightly better numbers.I swapped the prop out on several occasions in the same ponds/lagoons on the same day to compare them and it was always slightly better.
The biggest differance was the amount of rpms that it dropped.The best speeds were at about 3900,with the GT the best speeds were at 4250-4350 depending on prop wear.One day I had the boat at the GT shop and Kyle looked at it and said man if I knew that you wanted one of those I could have given you one.Thats when he told me about their results running them.
Tue Oct 27, 2009 8:05 am
Update checked out the hopkins on another motor,the hole shot was not worth a shit and it was slower by about maybe 1mph.This was only with 2 guys and a dog.
Tue Nov 03, 2009 7:27 am
Im running a prop Stumpy reworked to his specs and close to what the stock prop mold is going to be
Its a nice prop. good in the veggies and in the mud and I gained 1 MPH
I have about 15 hours on it so far and no problems
Wed Nov 04, 2009 7:36 am
Are these Stage 1 PD props available? when? Where?
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Mon Dec 14, 2009 2:45 pm
WERE DO YOU GET THE AFTER MARKET PROPS?
Tue Dec 22, 2009 8:48 pm
Similar experience with the Hopkins 12X12 Cleaver.- I lost 2 MPH, the hole shot was weak to say the least, and my RPM's went up about 250 RPM's. I sent the prop back to Glen and and he took it to a 13 or 13.5 pitch (he can't remember) I gained my speed back but my RPM's stayed at about 250-350 RPM's, over the stock. I did gain approximately 1 MPH over the stock. I am putting back on the stock in the AM. Engine was running 4450 with the Hopkins and 4150 with the stock. Much more comfortable running at 4150. Glen is going to add another degree of pitch to try to bring the RPM's down, but so far the Hopkins has not been better overall than the stock PD, which is ironically based on the Cleaver mold....
Sat Dec 26, 2009 6:50 pm
