It is currently Wed Jul 09, 2025 7:21 pm
Reply to topic  [ 3 posts ]
 Prop engage question?
Post Prop engage question?
Started my PRO-DRIVE this morning and soon as the motor started running my prop started turning with the PTO switch in off position. I'm thinking this just means my PTO switch is going out because after playing with it a Lil bit it started working right. What are thoughts on this issue. Thanks in advance for the advice.
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Sat Aug 30, 2014 10:39 am
Post Re: Prop engage question?
Sounds like you just had some rust on your clutch plates causing it to grab in neutral. Just cycle it a couple times and you should be fine.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Sat Aug 30, 2014 10:45 am
That's a very good possibility because after I cycled it a few times it started acting right.
Sat Aug 30, 2014 10:50 am
Users browsing this forum: No registered users and 33 guests
