It is currently Wed Jul 09, 2025 4:41 pm
Reply to topic  [ 4 posts ]
 Mud buddy hd mini 23 issue
Post Mud buddy hd mini 23 issue
Heres the problem when i first got the motor i put it on my boat a 1652 alweld ribbed jon boat ran about 27 with just me and about 23 with me a buddy and a hunting load.
Prop wore out (wouldnt go more than 7 mph or plane out) so got another one 11x10 hex
Since then iv ripped the old soggy wood floor out which lightened the boat a good bit. But am seeing much lower speeds with just me a small generator and my flounder gigging set up im pushing 18-19 iv tried all sorts of different trim positions and adjusted everything in the boat weight wise.
Could it be a bad prop??
Also when boats on the trailer i hear a weird noise coming from the lower unit kinda like a scratching grinding noise but their is no belt slack or pulley wobble that i have noticed.
Is it possible a bearing or something went out and is causing drag an slowing me down. In the water it runs just fine still pushing 3500 rpms. And their was a good bit of grease in the unit.
Any ideas
Tue Sep 09, 2014 10:05 am
Post Re: Mud buddy hd mini 23 issue
27 seems pretty high for a stock motor on a ribbed bottom boat. At 3500 rpms your not going to see 27 mph. Your speeds dont seem to far off 18-19mph @ 3500 Check your out of water rpms and adjust governor so you hit 42-4300. On a stock motor I was turning a big blade 3800 bout 21-22 mph. How many hours do you have on the motor. It may be time to work the heads valves are prob leaking
Thu Sep 11, 2014 7:11 pm
Close to 200+ hours an with decoys up in front of the boat an just me i got 27 running across the bay to my spot
Thu Sep 11, 2014 7:28 pm
Maybe your gps was off a lil bit , I'm running a 1542 rivited hull weighs nothing with short sides and I'm running 28 by myself at 4700rpm carb, cam, exhaust done. but b4 mods was running maybe 18 mph
Thu Sep 11, 2014 8:05 pm
Users browsing this forum: No registered users and 28 guests
