It is currently Wed Jul 09, 2025 10:52 am
Reply to topic  [ 8 posts ]
 PD Prop, Replace or not?
Post PD Prop, Replace or not?
My prop on 2008 PD has not been replaced in two years and while the cup does not look as deep/ wide(looks worn), the prop measures tip to tip 12-3/8". RPMS WOT run normally 4200, but now is closer to 4000 and when loaded it was around 3700/3800. Also notice I have to have it trimmed higher than normal to throw a normal rooster tail. Empty it seems to run pretty good, but still not the RPMS I would expect at normal trim level.
WOT in neutral was 4250/4275 so RPMs out of water looks good.
What is confusing me is the tip to tip measurement looks good, but it acts like the prop needs replacement from past experience.
Time to replace the prop?
Thanks
Phowler Extreme 1848 with 36PDFPR
Fri Sep 12, 2014 7:12 am
Post Re: PD Prop, Replace or not?
Less prop = more rpms. Sounds like you have something else going on.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Fri Sep 12, 2014 7:22 am
Fri Sep 12, 2014 9:05 am
Ah missed the part about the tail
Fri Sep 12, 2014 9:07 am
Thx...it certainly has the symptons of worn prop. Can the cup wear down without affecting tip to tip measurement? Thats my biggest question unless Im not measuring correctly.
Fri Sep 12, 2014 9:18 pm
It may be the prop....but i'm betting leaking valves. Might be time to have a leakdown test done.
Fri Sep 12, 2014 11:55 pm
check your throttle linkage. it may not be opening the govenor up enough under a load. over time they wear out and will make u chase your tail.
like the other guy said, a leakdown test will tell u what's going on with your valves and is easy to do.
Sun Sep 14, 2014 7:02 pm
Also check your boat for hooks
Sun Sep 14, 2014 9:57 pm
Users browsing this forum: Google [Bot] and 46 guests
