go devil long tail 25 help http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=56659 |
Author: | Pmbaldwin [ Tue Sep 16, 2014 3:36 pm ] |
Post subject: | go devil long tail 25 help |
I bought a used go devil long tail and need some help pulling the shaft.ImageUploadedByTapatalk1410903294.918677.jpgImageUploadedByTapatalk1410903359.278022.jpg |
Author: | Pmbaldwin [ Wed Sep 17, 2014 5:26 pm ] |
Post subject: | Re: go devil long tail 25 help |
The props cross threaded on so this is going to be fun |
Author: | gatorslayer [ Wed Sep 17, 2014 5:30 pm ] |
Why do you need to pull the shaft ? |
Author: | d_white [ Wed Sep 17, 2014 5:52 pm ] |
Author: | Pmbaldwin [ Wed Sep 17, 2014 6:36 pm ] |
I have a lot of play in the lower end of the shaft I ordered the seals and lower bearing it's a 99 so it's due. I'm having a hard time getting the shaft to move |
Author: | Pmbaldwin [ Sat Sep 20, 2014 3:59 pm ] |
Well after a week of no results I'm cutting the shaft off up by the yoke. I can't get the prop to move or get the shaft free |
Author: | flatontheplatte [ Sun Sep 28, 2014 7:48 pm ] |
If the shaft will spin you should be able to pull it. Did you remove the collar above the bearing and free the shaft from the yoke? Put a piece of 2x4 against the prop and beat on it with a mini sledge. |
Author: | SETx Longtail [ Mon Sep 29, 2014 7:16 am ] |
You need a small pipe wrench, and a big one (36"+)... Use the small one to bind the shaft up or the bottom of the U joint so it will not move. Take the big one and open the jaws up so it fits over the prop with the jaw opening facing the prop. The jaws should rest on the back side of the blades. Take a mini torch and put some heat directly on the hub where the shaft threads thru, do not overheat the shaft. I had to bounce and hang on mine a time or two but it busted loose. I was on the verge of cutting the shaft myself. I'll tell you this. Hitting it with anything will get you absolutely nowhere. The shaft is meant to absorb impact while running. You're simulating exactly that lol. You need steady pressure on the prop. The two pipe wrench method worked well for me. Now I remove the prop once or twice a yr and drown the threads in never seeze every time and don't have a problem at all. |
Author: | huck Finn [ Mon Sep 29, 2014 9:40 am ] |
Author: | huck Finn [ Mon Sep 29, 2014 9:42 am ] |
And when all else fails. , you can resort to this if your trashing the old prop. H Finn |
