It is currently Wed Jul 09, 2025 7:38 pm
Reply to topic  [ 10 posts ]
 go devil long tail 25 help
Post go devil long tail 25 help
I bought a used go devil long tail and need some help pulling the shaft.ImageUploadedByTapatalk1410903294.918677.jpgImageUploadedByTapatalk1410903359.278022.jpg
Tue Sep 16, 2014 3:36 pm
Post Re: go devil long tail 25 help
The props cross threaded on so this is going to be fun
Wed Sep 17, 2014 5:26 pm
Why do you need to pull the shaft ?
Jennings1977 wrote:
Way to chime in there buddy. Ill let you gobble my wiener to since you asked. You really got me with that comment. What are you about 18 yrs old tryin to fit in where you don't? You guys are some of the biggest egotistical bunch of pricks I've ever seen. Lol shut the f&$k up and get back on momma's tit.
Wed Sep 17, 2014 5:30 pm
Wed Sep 17, 2014 5:52 pm
I have a lot of play in the lower end of the shaft I ordered the seals and lower bearing it's a 99 so it's due. I'm having a hard time getting the shaft to move
Wed Sep 17, 2014 6:36 pm
Well after a week of no results I'm cutting the shaft off up by the yoke. I can't get the prop to move or get the shaft free
Sat Sep 20, 2014 3:59 pm
If the shaft will spin you should be able to pull it. Did you remove the collar above the bearing and free the shaft from the yoke? Put a piece of 2x4 against the prop and beat on it with a mini sledge.
Sun Sep 28, 2014 7:48 pm
You need a small pipe wrench, and a big one (36"+)... Use the small one to bind the shaft up or the bottom of the U joint so it will not move. Take the big one and open the jaws up so it fits over the prop with the jaw opening facing the prop. The jaws should rest on the back side of the blades. Take a mini torch and put some heat directly on the hub where the shaft threads thru, do not overheat the shaft. I had to bounce and hang on mine a time or two but it busted loose. I was on the verge of cutting the shaft myself. I'll tell you this. Hitting it with anything will get you absolutely nowhere. The shaft is meant to absorb impact while running. You're simulating exactly that lol. You need steady pressure on the prop. The two pipe wrench method worked well for me. Now I remove the prop once or twice a yr and drown the threads in never seeze every time and don't have a problem at all.
-Custom pool noodle
-stage 4 water wings
Mon Sep 29, 2014 7:16 am
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Mon Sep 29, 2014 9:40 am
And when all else fails. , you can resort to this if your trashing the old prop.
H Finn
BACKWATER PROSTAFF
Mon Sep 29, 2014 9:42 am
Users browsing this forum: Google [Bot] and 40 guests
