It is currently Wed Jul 09, 2025 9:43 pm
[ 7 posts ] |
PRO-DRIVE reverse help!!!
Quackhead62
Joined: Fri Nov 30, 2012 7:47 pm Posts: 931 Location: Maurice,La
So went run around the hunting lease motor went into reverse fine all morning. Went to back out to head home and all the hydro pump would do is hum when I hit the rocker switch for the foot to rotate 180 and if I'd hit the swith the other way nothing what so ever. What ya think this could be??
_________________ Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust Pushing a 17X54 Pro-Drive X-Series boat
Sun Oct 05, 2014 5:58 pm |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
 Re: PRO-DRIVE reverse help!!!
Start by checking all your connections.
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
Sun Oct 05, 2014 6:42 pm |
JLACOUR
Any other symptoms before it quit?
Sun Oct 05, 2014 7:02 pm |
Quackhead62
Checked all connections even swapped out the switch and still did the same thing. No other symptoms what so ever worked fine the rest of the day.
Sun Oct 05, 2014 7:09 pm |
banded-mallard
Mine did this a while back. Get a buddy, let him hit the switch and you help it turn around. What I found was my washer alignment wasn't right and it was binding up. I also found a few grease zerts that I missed. I greased the shit out of everything that touches and rubs together. You can also disconnect the ram from the gear and operate it manually. Its just one bolt, but atleast you will see if something is binding up. If all is good, check the fluid level, if that's good, while the ram is unbolted from the gear, operate the hydraulics. If the ram moves, then all your greasing and shit works and you broke free whatever was binding it up. If the ram doesn't move, then eith a bad switch (which you changed) or the seals in the reverse ram are bad and its leaking by.
Mon Oct 06, 2014 5:14 am |
Quackhead62
I will try that tonight thanks for the good info.
Mon Oct 06, 2014 8:40 am |
gbacres
My auto reverse needs me to help it get started. PD told me to change orings on the hydraulic cylinder. I plan to do that this week.
_________________ HRCH "Bear" Chocolate Lab 17x54 Prodrive SBX Center Console with 36 HP PD 16x48 Lowe D&W Jon 23 hp Vanguard with Swamp Runner Long Tail 16x36 Quachita Jon
Thu Oct 09, 2014 8:32 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 58 guests |
