It is currently Sun Sep 21, 2025 10:05 pm
Reply to topic  [ 4 posts ]
 GTR Big Blade vs. 11 inch prop
Post GTR Big Blade vs. 11 inch prop
I just bought a GTR big blade prop for a back up prop and to see what it would do. I currently have the 11 inch Gator Tail prop on my motor and can run 27-28 mph with a very light load. I put the big blade prop on to see what it would do and with the same load as the 11 inch prop I could only run a max of 24 mph. Just curious if they are just a tad too big to start out with and should run it more to get better speed. I switched back to my 11 inch gator tail prop for this mornings hunt. What are pros/cons of these two props. Thanks
1754 GT w/ 35 GTR Hoytafied
Sat Dec 19, 2009 11:23 pm
Post Re: GTR Big Blade vs. 11 inch prop
Pros- You run faster with the 11"
Cons- You run slower with the big blade.
You need the EASY Button.
:D
Sun Dec 20, 2009 10:23 am
Rpm's in the water with both and rpms out the water??
17x48 extreme stage 2 GTR
Sun Dec 20, 2009 3:18 pm
easier to get on plane with bigger load in shorter distance with big blade...smaller blader faster but not as good for load..
pros for smaller blade..more speed less tiller torque
cons.. longer to get on plane with larger loade
big blade is just the opposite
Sun Dec 20, 2009 4:59 pm
