Reef Runner for SD
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=59293
Author:  Tater [ Mon Jan 12, 2015 10:55 am ]
Post subject:  Reef Runner for SD
I run a river with sand bars & gravel beds. I also run a outboard with a "Reef Runner" on it that lifts the motor over the sand & gravel not to plow thru it.
I was wondering if I made a 3" (minimum) wide skid plate, attached to my rock guard if it would effect the handling or ? of my 35hp SD ????
Author:  Tater [ Thu Jan 15, 2015 9:23 am ]
Post subject:  Re: Reef Runner for SD
I guess nobody knows what I am talking about. Hard to understand them Northerners!
Author:  duckduckboom [ Thu Jan 15, 2015 9:33 am ]
PD has one
Author:  Tater [ Fri Jan 16, 2015 8:22 am ]
Thanks ddb,
I have goggled it & other words but not coming up with anything. I guess I will have to call them, I am really looking for a picture so I can get a better understanding of what they are.
Once I figure it out I was thinking of embossing somebody's girlfriends naked picture on it, I would have to stay with smaller boobs so I don't effect my speed.
Author:  HOTSAUCE170 [ Fri Jan 16, 2015 8:40 am ]
Is this what your talkin about
Author:  Tater [ Fri Jan 16, 2015 1:48 pm ]
Thanks Hotsause170,
I called it wrong, suppose to be river runner.
I was thinking of a skid plate to ride over gravel bars. That rock guard would help but not what I had in mind. Hopefully I posted a picture .
Author:  baron von [ Fri Jan 16, 2015 1:56 pm ]
I don't know if a device like that would work with a SD? I mean the prop on an outboard is totally submersed, SD is not – someone prove me wrong on this, please.
Author:  HOTSAUCE170 [ Fri Jan 16, 2015 2:56 pm ]
It would worry me if that bottom plate got bent and hit my prop from all the submerged stumps rocks etc. I hit. I may be thinking wrong but a surface drive motor is just that, the prop is right at the surface when the boat is on step so there is not much more that is gonna hit the prop that the hull wont strike first depending on how your motor is trimmed. like I say I may be wrong but that's how I think of it.
Author:  Tater [ Fri Jan 16, 2015 5:12 pm ]
I was thinking of installing a homemade skid plate about 4" from the end of the rock guard. I run through some really shallow water & thought if I could keep the prop from plowing through the gravel that I would not have to replace it so much, BUT I DID NOT THINK ABOUT THE BOAT DRAFT! if my boat goes over it than my prop should be running clear water.
Thanks for your responses !!
