It is currently Wed Jul 09, 2025 12:37 pm
Reply to topic  [ 11 posts ]
 9x9 to a 10x8 prop
Post 9x9 to a 10x8 prop
Has anyone switched from a 9x9 to a 10x8 on a surface drive if so how did it do
Wed Oct 08, 2014 6:54 pm
Post Re: 9x9 to a 10x8 prop
What HP and gear ratio?
Thu Oct 09, 2014 11:27 am
14 hp don't no the gear ratio its on a 10 hp Dixie mud frame
Thu Oct 09, 2014 5:38 pm
14 hp don't no the gear ratio its on a 10 hp Dixie mud frame just won't push
Thu Oct 09, 2014 5:39 pm
If the ratio is anything close to 1.5:1 you should be able to turn it. Get access to see the top pulley. Turn the prop 1 turn and see how many revolutions you get on the top pulley.
Fri Oct 10, 2014 11:20 am
I ran a 10x8 on a 12 hp and it did well. But not sure about the different gear ratio.
Sent from my beeper
Fri Oct 10, 2014 12:31 pm
Just checked the gear ratio 1.25 to 1 prop 1 revolution motor 1.25
Sat Oct 11, 2014 8:22 am
you should be ok dropping pitch and adding diameter it should almost be the same
Sat Oct 11, 2014 12:36 pm
How did it go? I have a 10hp frame with a prop issue.
Tue Oct 14, 2014 7:00 pm
Ended up being an rpm issue got 18 mph out of it with the 9x9 prop 2 men in the boat 1436 alumacraft
Tue Oct 14, 2014 8:08 pm
When you say RPM issue what do you mean. A buddy just bought a 10 hp dixie, with a broken belt. We fixed that, then the shaft broke so a new shaft was machined out of T1. Now we got it going and it also has a 9x9 prop. But can't get anything more than idle out of the motor when in the water with one person and no battery on a 14x40 flat john boat. It revs up find out of water but want once you set it down. Also what's the gear ratio suppose to be on the 10 hp. I appreciate any help. My 12 hp copperhead will shove that boat 22 mph with the same load. So it's hard to believe that's all the motor can do is lug along at idle.
12hp copper head
13hp homemade long tail
14x42 flat bottom
12x44 weld built semi V
Multiple outboards.
Fri Jan 23, 2015 11:51 am
Users browsing this forum: No registered users and 46 guests
