It is currently Wed Jul 09, 2025 1:51 pm
Reply to topic  [ 22 posts ]
 Used Longtail Prop Size
Post Used Longtail Prop Size
A few years ago I bought a 2001 Go-Devil LT that was a Briggs & Stratton 5.9 that had been modded to a 9.9. Never seen Go-Devil on it so could be homemade like the trailer that was sold with it. Anyways it appears it has 7 x 5 GD prop on it which I assume wasnt ever updated after the mod in comparison to GD prop recommendations on their website. Two questions, would a 8 x 4 GD prop make any difference in speed? What another type prop do anything? I mean I know its a 9.9, but a little would help a lot! Thanks for any input.
Mon Jan 12, 2015 9:29 pm
Post Re: Used Longtail Prop Size
What rpm,s r u running?
Mon Jan 12, 2015 10:20 pm
I dont have a tach.
Tue Jan 13, 2015 9:45 pm
40HP Gatortail
Tue Jan 13, 2015 9:48 pm
Go devil 7x5 has no cup, that's why they recommend 8x4.... So on a go devil prop u will go 1" wider on prop and less pitch! 7x4 is what's recommended by backh2o and mud buddy, both have cupping... I'd go with a BPS tiger 7x4, I like the heavier cup.... More cup, the more load and digging power, not a speed prop..... Want speed, go with Godevil 8x4
Tue Jan 13, 2015 10:17 pm
Not to hijack but where is it stamped on the prop? I just got a used gdlt 25 with a basically new prop on it. It has some visible cup but I don't know what size it it.
Wed Jan 14, 2015 9:42 am
Wed Jan 14, 2015 11:35 am
Wed Jan 14, 2015 1:44 pm
Wed Jan 14, 2015 5:50 pm
First a pic to determine if it is indeed Go-Devil or homemade. Second a pic of the prop because it doesnt even look lkke I could accomodate an 8 inch prop due to spacing.
Sun Jan 18, 2015 4:08 pm
Prop pic
Sun Jan 18, 2015 4:09 pm
Spacing with bottle cap
Sun Jan 18, 2015 4:11 pm
what the shaft length and post a pic from the side and if there a stamp number under the ujoint.
1236 Appleby
1436 Alumacraft Go-devil 5hp crawfish
1452 Delhi
Alumcraft waterfouler 16 beavertail 35hp sd
viewtopic.php?f=17&t=59558
Mon Jan 19, 2015 2:10 am
If it is a true godevil it should have a serial number underneath the upper U joint near the engine. but Ive never seen a GD that small, but the cav plate does look like a GD so it could go either way.
Wed Jan 21, 2015 11:01 am
if thats not a go devil whoever made it did a good job copying one
Wed Jan 21, 2015 11:09 am
Directly above transom clamp
Wed Jan 21, 2015 7:55 pm
Above the transom clamp closer to the engine
Wed Jan 21, 2015 7:56 pm
Underneath the tail and above the transom clamp
Wed Jan 21, 2015 7:58 pm
Im not seeing a seriel # but Im trying to find out if GD 8 x4 prop would allow any more speed? Do you think prop was changed when modded from 5.9 to 9.9? Idont think so because the cav plate would allow an additional inch on a bigger prop. I think im stuck with a really slow mud motor. Any answers/suggestions are appreciated.
Wed Jan 21, 2015 8:03 pm
The prop size I would look at would be a 7x4 or possibly a 8x4... If you dont have a serial number that corresponds to Go-Devil's records they will not sell you any parts... in that case call the guys at backwater and tell em you want a prop and what you have... Jake and Arlen are both great people to talk with on the phone and know their stuff, never mind their outstanding customer service...
1436 Lowe
Thu Jan 22, 2015 10:49 am
its a go-devil the serial number is under the u-joint on the plate you need to clean up the grease to find it.
1236 Appleby
1452 Delhi
Thu Jan 22, 2015 5:15 pm
its right under u joint like in this pic
1236 Appleby
1452 Delhi
Thu Jan 22, 2015 11:13 pm
Users browsing this forum: No registered users and 43 guests
