It is currently Wed Nov 19, 2025 6:09 am
Reply to topic  [ 3 posts ]
 Reverse Clutch/Brake Replacement Gatortail
Post Reverse Clutch/Brake Replacement Gatortail
Running down the river the other day and heard a terrible noise. Long story short, my gatortail is stuck in reverse. The prongs on the rear clutch are all broken and I found metal shavings in the cover. What should I look for when pulling the clutch as far as damage is concerned? Any help would be great.
Model is 2016 electric reverse 37
Gatortail Extreme 1854 w/ GTR 37 efi or 90hp Yamaha
Godevil 1860 w/ gd 35 sd with a Mikuni Carb Sold
Mon Nov 26, 2018 9:29 am
Post Re: Reverse Clutch/Brake Replacement Gatortail
Sounds like you can already see the issue. Remove the rear clutch and inspect it. Also check trans fluid for excessive metal while u are in there. Put eyes on front clutch also. Hopefully problem is only in rear clutch, this would keep the job not to hard
Mon Nov 26, 2018 11:49 am
10-4. I'm guessing the only way to inspect the trans fluid is through the bleeder on the drum. I planned on changing it out while I'm in there anyways.
I'm hoping the front is still good as it engages and shuts the engine down when I flip the switch.
Mon Nov 26, 2018 12:31 pm
