It is currently Tue Jul 08, 2025 12:07 am
Reply to topic  [ 15 posts ]
 GDSD lower seals
Post GDSD lower seals
Got grease coming out of the lower seal on my gdsd and making a shit of a mess. Where can I get replacement seals and what size are they? Not sure if my local tractor supply or hardware store would carry the size I need.
Fri Jun 05, 2015 10:59 am
Post Re: GDSD lower seals
Find a Dealer in your area and they will order it from go devil or just call godevil and they will send it to you. They are inexpensive
SENT VIA HOOT OWL!
I drive a Godevil and don't give a shit about your message!!!
MeatWagon
GoDevil 35 Surface Drive on a 13x60 MaxCraft AIRBOAT HULL!
Fri Jun 05, 2015 12:11 pm
Fri Jun 05, 2015 8:03 pm
Ok, and just out of curiosity why would it be the shaft? Could be bent?
Sat Jun 06, 2015 7:52 am
Sat Jun 06, 2015 6:19 pm
Sat Jun 06, 2015 7:27 pm
Thanks a bunch! Just bought this boat used and noticed it after I re greased it. What "speciality tools" will I need ?
Sun Jun 07, 2015 12:56 pm
Thu Jun 11, 2015 7:51 pm
It is a pretty simple project. Look at the go devil website and print up the owners manual. He has detailed instructions as to how it is set up.
40HP Gatortail
Fri Jun 12, 2015 5:50 am
I like units that heave wear sleeves for seals to ride on Vs the seal cutting a groove into the shaft!
Fri Jun 12, 2015 5:56 am
Sat Jun 13, 2015 9:59 pm
Sun Jun 14, 2015 1:54 am
Lol, I figured you'd be along with something to say....
Keep it greased, keep good seals and you won't have shaft and/or bushing issues. That is all, carry on.....
Sun Jun 14, 2015 8:41 am
Sun Jun 14, 2015 3:18 pm
Regardless of grease all it takes is some sand to work its way into the surface and scar it up. Shit happens. Wear sleeves are smart, Vs a worn out shaft.
Mon Jun 15, 2015 12:17 pm
Users browsing this forum: No registered users and 37 guests
