Which prop on Gtr? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=62195 |
Author: | MuddyWaterMallrds [ Wed Jun 10, 2015 8:06 pm ] |
Post subject: | Which prop on Gtr? |
Got a 2015 gtr stock minus exhaust, about due for a new prop, stick with the 3 blade or try something different? Thank you. |
Author: | msm8281 [ Wed Jun 10, 2015 8:08 pm ] |
Post subject: | Re: Which prop on Gtr? |
Gtr stock props are the best. 3 blade better for open water. 2 blade better for mud and grass. If you liked your 3 blade get another. |
Author: | duck_watcher12 [ Wed Jun 10, 2015 8:21 pm ] |
I went from a 3 blade to a mud buddy big blade and personally I haven't seen much difference in the 2 other than I lost 1mph on the top end and it reverses better than the 3 blade did. Like msm said if you like the 3 blade go with it. |
Author: | WhoDat88 [ Wed Jun 10, 2015 8:26 pm ] |
We were stuck like chuck with a 3 blade on the new style lower unit and Brady eased on through the junk with a two blade them pulled us out. I would say two blade. |
Author: | Jduck031 [ Thu Jun 11, 2015 2:02 am ] |
How many hours do you have on the 3 blade? |
Author: | BassmasterCia [ Thu Jun 11, 2015 8:14 am ] |
I like my big blade on my gtr. Its faster than my 10p 3 blade and the hole shot is a lot better |
Author: | HOTSAUCE170 [ Thu Jun 11, 2015 8:32 am ] |
Author: | MuddyWaterMallrds [ Fri Jun 12, 2015 8:16 pm ] |
I got almost 60 hrs on it, just wanting to get the best all around,I run open water and mud. |
Author: | Jduck031 [ Sat Jun 13, 2015 2:41 am ] |
I asked bc i was thinking you may have had low hrs like me. I have less than 20,run very little sand and prop is already sucking when i have a heavy load. I originally thought it was my motor, but it runs fine with a light load. Pretty sure itsthe prop now. 10p 3 |
Author: | msm8281 [ Sat Jun 13, 2015 6:31 am ] |
Leaking valves if your prop is in good condition but the performance gradually tapers off |
Author: | debo [ Wed Jun 24, 2015 11:41 am ] |
x2 ^^^^ same issue I had with my boat. I thought it was my prop, ended up being the valves. They were leaking pretty bad. Boat ran normal with a light load as soon as I added another person she was a turd. I even went to a 10p and it helped but still wasn't like new. I would look into a leak down test!!! |
Author: | Jduck031 [ Wed Jun 24, 2015 1:10 pm ] |
Sounds like the same problem.. Thanks |
Author: | Jduck031 [ Wed Jun 24, 2015 1:19 pm ] |
How much leakage is too much? I've heard of people tapping on the valves with a rubber mallet and it sometimes cures the problem |
Author: | Jduck031 [ Wed Jun 24, 2015 1:26 pm ] |
How much leakage is too much? I've heard of people tapping on the valves with a rubber mallet and it sometimes cures the problem. Finally, would that be covered under the warranty? |
Author: | mudxxed [ Wed Jun 24, 2015 2:02 pm ] |
Its gotta be an astronomical amount to be covered under warranty. Best thing to do is deck heads, and 1pc valves. Hit up boat dr or jamie b and they will get you setup straight. Paired with a mikuni carb and headwork, itll be like running a completely new motor. I could never drive/own another stock motor. |
Author: | Jduck031 [ Wed Jun 24, 2015 3:16 pm ] |
Just put it in the shop, they say it will be covered by briggs warranty. Thanks for the help and the advice. Had a mb 23mini for years, so I'm happy with the way it ran before this started... Atleast until warranty is up lol. I've got a 250merc on bass boat, so they all seem slow to me. |
