Beavertail 35hp surface drive prop help http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=62292 |
Author: | bueller [ Wed Jun 17, 2015 9:48 pm ] |
Post subject: | Beavertail 35hp surface drive prop help |
Recently bought a 1754 Beavertail boat with 35hp Beavertail surface drive. The boat runs ok (24mph) but has terrible holeshot and seems like it cavitates alot. It does have factory pods and I feel like they may be directing too much water away from the prop. It likes running the prop deep and barely shoots any rooster tail. Any advice on prop selection? I also use it for bowfishing so the problem is multiplied when theres a heavy load (i undestand a mud motor isnt going to work well for this application but i think a better prop would help). |
Author: | brickgw [ Thu Jun 18, 2015 8:45 am ] |
Post subject: | Re: Beavertail 35hp surface drive prop help |
If you do a bit of searching you'll find that PODS and SD's are a generally considered to be a bad combination. Your correct about them diverting water from the prop. |
Author: | Bigbuckfever [ Thu Jun 18, 2015 12:19 pm ] |
I would definitely remove the pods Sent from my iPhone using Tapatalk |
Author: | Jduck031 [ Wed Jun 24, 2015 12:35 am ] |
Have a 3rd pod put between the 2 you have and mount your motor on it. Then you got a redneck hunt deck |
