It is currently Tue Jul 08, 2025 7:30 am
Reply to topic  [ 35 posts ]
 This is gonna suck
Post This is gonna suck
Took the kids out fishin this afternoon and when i pulled the boat out this is what i found. Not firmiliar with the lower ends on these, but looks like i gotta seal job comin up next weekend.
Sun Jun 14, 2015 6:13 pm
Post Re: This is gonna suck
What year do you have?
I am having the same issue with mines, but it comes out of the top the housing at the clutch.
I ordered a new prop seal to see if the water if forcing it out the top.
Drain your LU oil and see if theres water in it. if so, then it will probably be your lower prop seal, which should be an easy fix!
Refurbishing a Prodrive
Sun Jun 14, 2015 6:39 pm
Its an 06. When i got home i pulled the plug and theres no water in but it was real dark and thick like never been changed before thick. It has 300 hours on it and ole boy i got it from said he just did all that but i was to anxious to check and guess i got the shaft. And its not coming from the clutch area its down lower than that. There was another thread on here i was reading and it doesnt seem to be to difficult.
Sun Jun 14, 2015 7:06 pm
Sun Jun 14, 2015 7:10 pm
Yeah i assume its just the upper but gonna get em all done while i got it opened up so hopefully theres no more issues before the season as well.
Sun Jun 14, 2015 7:15 pm
Any idea on what the set runs?
Sun Jun 14, 2015 7:16 pm
Sun Jun 14, 2015 7:20 pm
Thats a bit of good news.
Sun Jun 14, 2015 7:27 pm
Sun Jun 14, 2015 7:38 pm
Will do bud, thanks for the intel.
Sun Jun 14, 2015 7:44 pm
Somebody will correct me if I'm wrong....or may confirm if right...but, call PD and let them know what you have. I think they have an upgrade kit for the Gen I LU's that will give you the greased outdrive shaft and HP seals.
Mon Jun 15, 2015 7:25 am
damn...
how often does this happen?
GatorHide - MB
Mon Jun 15, 2015 9:36 am
Gonna call after lunch, ill post what he tells me to help confirm.
Mon Jun 15, 2015 10:13 am
Both times that have worked on my gen 1, KP has only suggested a new top seal and bottom seal nut. No mention of any type of conversion. I have changed my top seal twice in 6 yrs
1854 Prodigy DPE Level 3 HDR
Mon Jun 15, 2015 10:25 am
Just got off the phone with prodrive and no conversion for gen 1 its only for gen 2s. Set of seals and nut about 100 bucks and they refund 65 when they get the nut back. So no an exspensive fix and i get to learn some more about the lu.
Mon Jun 15, 2015 11:35 am
Post up how you broke it down to fix it if you don't mind. Had to get the upper done on my 06 too but I had a guy do it for me because I wasn't sure what to do . May try to do it myself next time
1850 & 36pd
Mon Jun 15, 2015 12:19 pm
Will do probab ly this weekend.
Mon Jun 15, 2015 12:36 pm
Be holding on to your lower unit or have a block under it when you take the 4 LU spacer bolts out. Its going straight toward the floor when the last one comes out :o :oops:
Mon Jun 15, 2015 12:52 pm
Thanks, havent done this task yet so any intel is appreciated.
Mon Jun 15, 2015 1:09 pm
Mon Jun 15, 2015 2:20 pm
More
Mon Jun 15, 2015 2:22 pm
1 more, all the other info you may need will be in the motors section of PD web site, gen 1 owners manual
Mon Jun 15, 2015 2:24 pm
Hope the pics are clear enough for you guys
Mon Jun 15, 2015 2:25 pm
Pics are out of order. Order is 3,2,1,6,5,4,7
Mon Jun 15, 2015 2:30 pm
Step 1: Take the engine/clutch off top of the tower. Undo the engine mount bolts, probably gonna need a 2x4 or a couple of pry bars to get it to break free.
Step 2 - Place a floor jack snug against the skeg while tower is in the vertical position. My Gen II had six bolts at the top of the tower to release the spacers and LU. If the Gen I's have 4, more power to ya! Back out the tension knob, take the top bolts out, lower the floor jack. Depending on how far off the ground your boat is on the trailer, you may need to trim up to slide everything out. Have a bunch of plastic visqueen laying underneath to catch the excess grease and to have a place for the LU assembly.
Step 3 - Unbolt the top seal and replace.
Be careful with the flanges on the inner bushings. They are pretty "friable" and the lips can break pretty easily.
Here are a few pics.
Mon Jun 15, 2015 2:47 pm
Are those manuals available to buy?
Mon Jun 15, 2015 4:26 pm
Thanks for the pics looks more in depth than i had thought but doable. Ordered the seal kit so hopefully this weekend can get on it.
Mon Jun 15, 2015 4:27 pm
No idea. You can download the owners manual PDF from PD web site. KP sent me the seal swap print out 6-7yrs ago. He may still have it, but this is all there is other than the owners manual. Should work for your purposes, there is nothing complicated about the LU design
Mon Jun 15, 2015 4:32 pm
Just realizing JD had posted those pages from the manual. Def different from the Gen II.
Most liberals seem to suffer from the same mental condition....it's called stupidity!
Mon Jun 15, 2015 7:20 pm
Looks simple enough just something new to me. I work all day with sheet metal and bondo and welders. All the pics and manuals will definitely help. I downloaded the gen 1 manual and printed as another reference. Anyone know if i can get a carb rebuild kit from prodrive? Figure while its apart i can do that and go through other seals and gaskets probably replace just to ease my mind.
Mon Jun 15, 2015 7:29 pm
My guess would be to call BoatDr on that
Tue Jun 16, 2015 1:16 pm
Thanks.
Tue Jun 16, 2015 2:38 pm
Well got the seal, which i thought was a set, yesterday. It was only the nut in front of the prop. Simple task other than getting the prop off. Drained the remaining fluid and filled her back up seemed to do the trick. Apparently the inner seal in the n ut wen t bad allowing water to get in and oil to come out the vent. Gonna dunk her this weekend and hopefully all is well. Thank all you guys for the help.
Thu Jun 25, 2015 2:39 pm
Im surprised they didn't send you the top seal also . good luck I hope it solves your problem and gets you back out there.
Thu Jun 25, 2015 3:02 pm
Yeah thats what i thought as well, but we shall see. It made since when the guy from prodrive explained it and thus far spinnin the prop on land no leaks. But ill water test it and go from there.
Thu Jun 25, 2015 6:06 pm
Users browsing this forum: No registered users and 24 guests
